Old 04-04-2004, 11:20 AM   #1
squeeky's Avatar
Sticky Black Water Valve
My black water valve is getting hard to push in and out. Mostly in. The arms are showing signs of rust. Is there a good way to address this? Can I oil these arms?
squeeky is offline   Reply With Quote
Old 04-04-2004, 11:58 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I had this problem on a previous SOB trailer and solved it by using a black water treatment that had a lubricant in it. I recall it may have been coconut oil. After about 2 dumps, the valve worked smoothly ever after.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 04-05-2004, 08:27 AM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
wal mart has a product that lubes the valve. i clean my tanks and close them up and dump some of the conditioner in the empty tank. has worked for me. also do a good clean out when you dump. i always dump 5 gal of water down the toilet after i dump to get the desidue out. and i always see toilet paper in the out flow. that may be your problem closing down on residue.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 04-09-2004, 10:47 AM   #4
squeeky's Avatar
Thank you for input
Funny you should mention coconut oil . . . I had a friend suggest the same thing. So far, the oil seems to working fine. I do have a question though when I'm hosing out the black water tank; Does this water go directly into the tank? So when someone suggest filling with 5 gallons after cleaning are you talking about from this point or actually flushing from the toilet because that would seem to me to wear out the toilet a lot faster. Any thoughts?
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Black Water Valve Opinion Deppdog Waste Systems, Tanks & Totes 4 09-11-2003 04:27 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
