Old 06-26-2003, 03:12 PM   #1
pilgrim_still's Avatar
Send a message via Yahoo to pilgrim_still
Source for Thetford valve?
1973, 31', SLY, rear bath -- retrieved from 10-12 years of neglect
aka M&MT (Mildew & Mouse Turds)
Noting rust in the inside-the-rear-bumper storage compartment, I investigated. At the present time, the rear bumper is off (only had to drill-out two of the four bolts) and the underbelly skin is loosened forward for about six feet. The angle iron supports are rusted, especially the most rearward one. The only rust on the galvanized pan under the holding tank is where it is in contact with the angle irons. The frame of the trailer and the frame crossmembers seem fine -- just some light surface rust.
I plan to "treat" the rusted angle irons with a great product I get from Gemplers farm supply (recommended for honey wagons!). For support I plan to insert two pieces of strap iron (1/4 x 2) and rest them on the lower shelf of the frame. I'll spot weld them in place. I have some very think plastic I'll put between the galvanized pan and the supports (both the angle irons and the strap iron).
Before I do all this, I thought I should check out the integrity of the tank (black water only on this model). The PO had assured me that "everything works", specifically mentioning the holding tank. Well, considering the proven lack of veracity of that statement with all the other systems, I filled the tank, after providing support with a large piece of 3/4" plywood and a car jack. Great! The tank does not leak -- but, the Thetford valve does! I removed all the plumbing retrograde to the valve and the gasket is old, dry and cracking. Even after cleaning with a toothbrush, the gate won't adequately seat in the gasket.
So, I called Inland for the part, but the young lady needed their part number...promised to call me back. I've tried other sites, including Thetford corporation, but can't seem to find the valve.
It is Thetford, 01447 Slide E-Z Valve, D.W.V., IAPMO, T-1169.
I assume I need the entire valve system, rather than just a gasket set. Anyone know of a source?
Oh, yes, I threw the toothbrush away.
JimF - a pilgrim_still <*}}}><
Waterproof, Louisiana
1973 Sovereign
"Preserve Game - Use a Trained Dog"
pilgrim_still is offline   Reply With Quote
Old 06-26-2003, 03:46 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Most RV places will offer a seal kit. The main thing you need is the number off the valve, it makes a difference if the valve blade is metal or plastic. You split the valve by loosening the screws and replace the gasket and seals. I think I paid 15.00 or so for the seal kit.
The bag that the seal kit is in lists the valve numbers it fits, so a bit of looking will benifit you by saving the cost of a valve and the associated plumbing work.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-26-2003, 09:42 PM   #3
ericandterry's Avatar
Images: 16
Talking Thetford valve
Your in luck!! I just got done with the dozens of phone calls and emails to find just the source your looking for.
Call American Way R.V center in Boise Idaho. 1-800-345-6651. Fantastic people and very quick in shipping. They we're the only place that I could find that had that exact same valve your looking for. Even new in the package !
You may want to look at the threads reguarding removal of the valve seeing as you may need a few more replacement parts for the repair like I did. Somewhere along the line someone A.B.S glued all the fittings together in my Minuet including the Valve assembly and into the tank. So needless to say I had to cut and break out most of the parts and replace them.
Good Luck
ericandterry is offline   Reply With Quote
Old 06-26-2003, 09:46 PM   #4
Images: 16
Talking Part number
I grabbed my paperwork. The Airstream part number for the T-01447 is 008706 (Got that through Airstream) The valve was $42.19 with $5.95 shipping to Washington.
Good luck again
Old 06-27-2003, 06:09 AM   #5
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
Just a word of caution. Mouse dropping from the deer mouse may contain hantavirus. see this thread for more info
http://www.airforums.com/forum...?threadid=4343
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 06-27-2003, 01:08 PM   #6
thanks
ericandterry,
Thanks very much for the info. I called American RV and ordered the valve. At least, I think it is the correct one. Their salesman said the valve should have a label with more info on it than I was giving him. However, he seemed to have the correct valve (it is tough to see over the phone!).
My shop vac has a long hose. I can vacuum inside the TT with the exhaust outside the trailer. We have no evidence of any recent rodent activity, so I am comfortable that the hanta virus risk is minimal. Thanks for the warning.
Raining here today...can't work on the A/S...sigh.
1973 Sovereign
Old 06-28-2003, 02:12 PM   #7
Palm Bay , Florida
Images: 34
but... but... but... you live in Waterproof. Why would rain be a problem?
Vic Smith
WBCCI #6782
Old 06-28-2003, 05:00 PM   #8
- oxymoron
Waterproof, Louisiana is the greatest example of an oxymoron I know!
1973 Sovereign
Old 07-11-2003, 09:32 AM   #9
progress
My Thetford valve has arrived and is ready to install. Thanks ericandterry.
When I removed the old valve, the flange to the tank came off. A previous "repair" by a PO had used a radiator clamp and a putty-like substance (I said "putty-like", not "potty-like"). A local plumbing supply store employee suggested using Oatey All Purpose Cement (for PVC, ABS, CPVC) to replace the flange in the tank.
What is the forum's opinion?
tia,
1973 Sovereign
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 03:20 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
