Old 10-03-2013, 08:21 AM   #43
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Super Trooper. I have the Sewer Solution and I like it. I added a "Y" valve to my wash hose so that I have two 30" ends. I connect one to the SS and the other, with a back-flow preventer, to the AS internal spray connection. That way, I can switch the flow back and forth with any difficulty. Works well for me.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 10-03-2013, 08:27 AM   #44
Will_Brule's Avatar
Palestine , Texas
Should have said "without" any difficulty.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
Old 10-03-2013, 11:33 AM   #45
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
I have the same set up. And while I own the SS and like it, I use my regular "Rhino" hose more often than not. The reason is because it is faster.
I am fortunate to have an internal rinser in my black water tank and have found it easier and better at cleaning out the black water tank than the SS. However I am very glad to have the SS and a "backup" because I have been in some situations where the regular hose would not have worked since the AS is low and occasionally you run into RV dumps that are higher than the outlet on the AS.
However if you do not have an internal rinser, using the SS or the "Camco dual flush" is essential in fully cleaning out the black water tank in my opinion.
Hope that helps.
-J
jpons is offline   Reply With Quote
Old 10-03-2013, 11:52 AM   #46
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Cool idea!!
The atoms of our bodies are traceable to stars that manufactured them...We are not figuratively, but literally stardust.
PharmGeek is offline   Reply With Quote
Old 10-03-2013, 12:52 PM   #47
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Hope that helps.
-J
We still use a rhino slinky too.
Faster is good.....
What's gooder is poop dumping at home where faster doesn't matter.
Side benefit...traveling with an almost full black tank makes for a much cleaner tank. Slosh,slosh,dump,dump...
Plus the black tank flusher works a lot better on city water pressure.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-03-2013, 08:29 PM   #48
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Thanks everyone! I have the switching Y valve. I'll just add another hose. I just wanted to avoid having the plumbing side of the trailer look like a refinery!
SuperTrouper is offline   Reply With Quote
F150 Ecoboost Owners With Problems LFM Tow Vehicles 45 01-29-2016 10:16 PM
Do you have problems getting WiFi in your Airstream? WiFiRanger Electronics & Connectivity 27 02-08-2012 01:01 AM
Suburban furnace problems? New NT-30... edglenn Furnaces, Heaters, Fireplaces & Air Conditioning 13 11-10-2011 08:16 PM
Water heater problems BLUEBELL Water Heaters, Filters & Pumps 1 07-10-2011 06:14 PM
