Old 08-20-2015, 05:35 PM   #1
1979 28' Airstream Excella 28
Brooklyn , New York
Solid state tank monitor
All of the lights went out in this tank monitor. Any ideas if this is common? A few weeks ago the water pump light and generator light worked, now none do. Does anyone know where I can find a wiring diagram for this? I bought it recently and don't want to fill the tanks in risk of hurting something. Any help is greatly appreciated.Click image for larger version
Name:	ImageUploadedByAirstream Forums1440113712.294049.jpg
Walkietalkie is offline   Reply With Quote
Old 08-20-2015, 06:40 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I bet 80% of the Airstreams tank monitors in one degree or another do not work properly. Good luck with yours.
MICHAEL
Solid State Central Control System Panel gandichen Electrical - Systems, Generators, Batteries & Solar 1 04-14-2015 10:39 PM
Solid State Control Panel ElCamino Man General Repair Forum 4 09-05-2012 03:24 PM
1979 27' Argosy and Solid State Control Panel lbrownah Electrical - Systems, Generators, Batteries & Solar 10 05-16-2010 09:27 AM
Solid state control system ?'s Skamper1 Batteries, Univolts, Converters & Inverters 2 03-29-2010 01:28 PM
Help - Solid State Control Panel SnoSheriff Electrical - Systems, Generators, Batteries & Solar 5 07-20-2009 06:55 PM
