Old 02-08-2012, 05:40 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
smell
I have noticed a slight order in the trailer that at first I though may be coming from the either the grey or black water systems. But I have cleaned both and still have that faint order. I thgink I have read about stopped up sewre vents can sometimes cause an order. But I don't know if that is correct. Anyway maybe someone will have some input. Thanks.
Don
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 02-08-2012, 05:49 PM   #2
1979 Argosy 27
Fort Fairfield , Maine
Don't want to scare you, but check thoroughly for any water leaks, around the ends on the floor, doors. Hope you are dry but sometimes an ordor is signs of mold, rot, etc. At least that's what I've found in restoring serveral campers.
Good luck, hope I'm wrong.
Stumpjumper is offline   Reply With Quote
Old 02-08-2012, 05:55 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
A sewer-like odor can also come from a boiling battery. (Happened to us!) Make use of your sniffer all around, including near the battery.
Lynn
WBCCI 21043
Old 02-08-2012, 06:10 PM   #4
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
I'll second the battery possibility. It took us a long time to figure out the smell was coming from a cooked battery.
10Smiles is offline   Reply With Quote
Old 02-08-2012, 06:42 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
We sometimes get a downdraft through the vent fan opening into the bath room, but only when the fan is off. This vent fan is very near the sewer tank vent on the roof of my trailer. If the wind is just right it will occasionally below in the sewer gas. It has happened more than once. I would get a good strong whiff and then the smell was gone. Took me a while to figure this out.
You can also get that smell if the toilet flange seal has deteriorated. I have had this problem also.
Alan
Old 02-08-2012, 06:43 PM   #6
1974 Argosy 20
Kooskia , Idaho
Along with the other possibilities suggested, I have run into situations where the smell was actually propane. In very small amounts, it sometimes, at least to me, does not smell like propane, but more like musty, or sewerage odor. If your oven control is on "off" but not all the way CCW to "pilot off" you will have a very small amount of propane bleeding into your rig, and it can take on that odor you are picking up.
Worth a look or thought anyway.
Old 02-08-2012, 07:45 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Odors from the grey tank can enter the trailer if the P-Trap to a sink or shower has gone dry.
Richard
Old 02-08-2012, 09:29 PM   #8
Ottawa , ON
Look to the "soft" parts, too: carpets, curtains, cushions, pillows. These things tend to be magnets for odour, and don't give up the smell easily, if they trap some.
Old 02-09-2012, 06:48 AM   #9
adonh's Avatar
1976 31' Sovereign
Lynn
That could be it, my battery is dead and won't hold a charge. I had not gotten around to replacing but I will today and see if that takes care of it.
Don
Don Hardman
1976 31' Sovereign
Old 02-09-2012, 07:02 AM   #10
adonh's Avatar
1976 31' Sovereign
That's it bad battery
That's it, bad battery. I can smell it right there at the battery box. But now I have another problem. None of my keys will unlock the battery compartment door. I have not opened this in a while but I have the same keys i have always had. How can I get this open, any suggestions.
Don Hardman
1976 31' Sovereign
Old 02-09-2012, 07:38 AM   #11
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Is this the seal between the toilet and the toilet flange ? Or is there another
one?
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 02-09-2012, 07:46 AM   #12
adonh's Avatar
1976 31' Sovereign
Found the key
I found the key and was able to open the battery compartment. It was definitely the battery that was causing the smell. Now I am off to buy a new one.
It may also be time to look into a new converter that does not burn up the battery. But that's another thread.\\
Thanks everyone
Don
Don Hardman
1976 31' Sovereign
Old 02-09-2012, 07:50 AM   #13
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
You might want to check out why the battery was boiling, causing the smell. In our case, it was a defective charger/converter.
Lynn
WBCCI 21043
Old 02-09-2012, 08:54 AM   #14
one?
Jo
Gasket between toilet and flange was the source of my bad odors. They do wear out over time.
Shake the toilet. If it wobbles that is a tip off.
handn is offline   Reply With Quote
A/C mildew smell arcamedies Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-27-2012 09:57 AM
What's That Smell?? 10Smiles Electrical - Systems, Generators, Batteries & Solar 13 10-06-2011 08:10 PM
Bee Hives under belly pans - is that the smell? godaddy64 General Repair Forum 0 09-29-2011 04:44 PM
I smell burning wires! crazeevw Classic Motorhomes 32 09-26-2011 08:13 PM
I Don't want that smell to go away!!!! THEPILL 2006 - 2010 International 12 12-30-2010 07:39 PM
