Old 02-09-2012, 12:36 PM   #15
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by Gypsy Jo View Post
Is this the seal between the toilet and the toilet flange ? Or is there another
one?
Jo
Yes the one between the toilet and flange, and it can be replaced easily. It took me less than 30 minutes, not including a trip to the RV supply to get the seal. (ODM is a 20 minute drive for me)
Just turn the water off and then disconnect the water line at the toilet. Remove the two nuts from the flange bolts that hold down the toilet. Then lift the toilet and carry it outside where you can see it better to check for cracks, corrosion, etc and clean it up before installing that new seal. On my Thetford the flange seal is a foam ring that looks like a dough-nut that slips on the bottom of the toilet..
Alan
A/C mildew smell arcamedies Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-27-2012 09:57 AM
What's That Smell?? 10Smiles Electrical - Systems, Generators, Batteries & Solar 13 10-06-2011 08:10 PM
Bee Hives under belly pans - is that the smell? godaddy64 General Repair Forum 0 09-29-2011 04:44 PM
I smell burning wires! crazeevw Classic Motorhomes 32 09-26-2011 08:13 PM
I Don't want that smell to go away!!!! THEPILL 2006 - 2010 International 12 12-30-2010 07:39 PM
