Old 01-29-2003, 12:18 PM   #1
Jabba's Avatar
1955 30' Liner Commodore Vanderbilt
Wayne County , Michigan
Slinky Storage
I'm curious and open to ideas on how everyone stores their dump hoses? Our '55 has nothing other than the side trunk, which is open to the interior of the trailer. P.O. stored the hose there, which I find gross. Any ideas or suggestions for storage that will be visually pleasing and still provide ground clearance. (Bumper curves at ends)
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 01-29-2003, 12:31 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I use a plastic box with a snap on lid. Put the hose and the other related accesories in it. It stows in my side bin. Has wheels also so I roll it out, use the hose, roll it back, stow.
Old 01-29-2003, 12:38 PM   #3
Rickk48's Avatar
Bigfork , Montana
On my '01 Bambi I have two Plastic tubes attached underneath the trailer. One is 48", the other is 60" so I can store a 10' and a 20' with connectors. These tubes can be purchased at Camping World or other RV places and are easily attached.
Rick Klein
Seeking another Bambi
'08 Honda Ridgeline
Rickk48 is offline   Reply With Quote
Old 01-29-2003, 03:18 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I've seen the "tubes underneath" solution retrofit on vintage units too. At the Rocky Mountain VAC Rally this past summer, one person used 4" PVC piping & threaded caps, typical pieces that are available at Home Depot. They just riveted them underneath with aluminum straps...looked like it worked pretty well.
I looked through my pictures, but sorry, I couldn't find one...
Shari
Old 01-29-2003, 03:23 PM   #5
Jabba's Avatar
The pvc tubes are what I was thinking, just seeing if anyone had a "better mousetrap."
Jason & Veronica J.
S.E. Michigan
"Hawley"
TAC Member MI-6
Old 01-29-2003, 05:50 PM   #6
Factory installed
Jason,
Mine came with the PCV riveted underneath. A/S painted it to match the belly color.
PO added another longer one for additional storage.
John
John is offline   Reply With Quote
Old 01-29-2003, 10:31 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Slinky Storage
Greetings Jason!
As part of the restoration on my '64 Overlander, I had two sewer hose storage tubes added to my coach. They are sized for the 10' length of sewer hose - - if I had it to do over again, I would have insisted on the larger size as I rarely use my 10' hose, but nearly always find that the 20' hose is needed. Ace Fogdall RV installed them for me, and they were one of the more reasonable modifications. My next goal is to have a third storage tube added for my three telescoping flagpoles so that they won't be a continuing nuisance in the bedroom hallway. You can see the two tubes that are currently on the coach in the photo below (they are just behind the rear wheel.
Good luck with finding an acceptable solution to your problem.
Kevin
Kevin D. Allen
AIR #827
AS/RV storage in Chicago area... crazylev On The Road... 8 05-28-2011 06:59 AM
Inside Storage cedarfield On The Road... 6 03-06-2004 02:36 PM
Storage fees cosmotini Our Community 28 02-04-2004 02:24 PM
Short-term storage in central FL? rluhr Our Community 9 12-02-2003 09:36 PM
Long term storage accomodations 85MH325 Our Community 32 11-02-2003 09:52 PM
