Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 05-14-2010, 09:58 PM   #1
1965 17' Caravel
langley , British Columbia
Shower hookup to grey tank
I have a 1965 caravel,,,i`m putting in the original bathroom unit ,,,i`ve picked up a grey tank that fits between the back cross rails and it hold 14 gallon,,,,i`m putting in an inlet on the side to take in the 2 sinks,,, and have a vent on the top corner ,,,and to drain the tank is quite easy,,,but i`m not sure about the shower drain,,,,since the tank is up against the plywood {5/8 in.} and the shower outlet is on the top side of the plywood,,,how do i make the hook-up and whats to stop the water from slopping back up thru the shower drain,,i`m told i can have a threaded or a smooth flange installed for the shower,,,i hope somebody can help,,,,,,,thanks keith
trout-fly is offline   Reply With Quote
Old 05-15-2010, 06:38 AM   #2
Images: 59
If you don't do something you will get water sloshing back into the shower pan every time you accelerate of turn a corner.
Your options as I see it are to put in a gate valve between the shower and the gray tank, or a check valve.
A gate valve is something you would need to open and close whenever you used the shower.
I would put in a check valve. Use the plastic ones made for sump pumps, they come in various sizes with hose clamp ends. Buy them at your HD or Lowes for about $10.
I also put a stopper in the shower pan when hitting the road.
Here is a picture of how I did mine. The check valve is the blue & red item in the lower center.
Shower grey water reflux from kitchen sink jordandvm 2002 - 2005 International 12 12-17-2011 02:10 PM
Gray/black tank hookup Apache_Camp All Argosy Trailers 4 10-03-2009 06:54 PM
Fresh Water Tank to Grey + Shower Pump? foshejh Fresh Water Systems 7 12-08-2005 09:22 AM
No grey tank, no sewer hookup Safari Tim Our Community 8 07-11-2003 07:36 PM
One more grey tank ?? escapeez Waste Systems, Tanks & Totes 2 09-09-2002 10:55 PM
