Old 09-05-2016, 09:38 PM   #1
frankfarmer's Avatar
1992 34' Limited
Snead , Alabama
Shower floor drain broke loose from holding tank???
Shower floor drain broke loose from the holding tank, what a problem, water leaking now???? rotten wood some. Any idea how to fix it? How hard is it to take the entire plastic shower floor out???
Thanks, kind lost on what to do, but leak is rottening the floor, gotta stop it.
Frank Burgett, Owner
Burgit Hill Herefords
Registered White Face Hereford Cattle
1099 Dailey Road, Snead, Al 35952
frankfarmer is offline   Reply With Quote
Old 09-06-2016, 12:18 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I would explore cutting an access panel in the belly pan.
CRH is offline   Reply With Quote
Old 09-06-2016, 12:43 AM   #3
Boxite's Avatar
2008 22' Sport
Ordinary people built it...so ordinary people should be able to fix it.
You might wish to go to the airstream.com website and download the plumbing manual to get an idea of the pipe routings and surrounding structure. Chances are you don't have to remove the shower entirely, but only remove an adjacent wall or cabinet to get beneath to make the repair and dry it out.
If the floor really is rotten from a long-term leak...well, then yes , you'll likely want to remove a lot more to replace at least that section of flooring, but beware... lots of folks get into those sort of repairs and have a difficult time deciding exactly where to stop removing old stuff and end up disgusted or doing large-scale renovations.
Beware of just letting anyone do the work, also. There's a so-called RV repair place that specializes in Airstreams near me and he's got at least 50 or so trailers disassembled and it looks like lots of work is sitting there unfinished. Don't let someone tear it apart and then let it become a stationary object.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-07-2016, 11:53 AM   #4
1992 34' Limited
Snead , Alabama
Thanks, I'm not sure what to do, had a good guy look at it, big job taking out the holding tanks, fixing it, ????
Shower drain broke lose from holding tank?? frankfarmer Waste Systems, Tanks & Totes 2 06-03-2012 11:11 AM
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 07:45 PM
Holding tank strap is loose Jim J Waste Systems, Tanks & Totes 9 07-10-2008 10:40 AM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 08:50 AM
