Old 08-14-2004, 11:52 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Shower drain seal
The shower drain in my '71 Safari appears to be leaking.
I am going to reseal it but I am not sure if I should use silicone or plumbers putty.
I think the shower pan is fiberglass but I am not sure.
Any ideas what I should use?
Thanks!
-Tim
theVAP - Airstream Podcast
Old 08-14-2004, 12:05 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Plumber's Putty
Plumber's putty would be my vote, at least if it doesn't work it is easy to clean off. I would do a very detailed inspection and make sure that there are no cracks in the fiberglass pan in the immediate are of the drain hole in the pan.
Aaron
WBCCI #XXXX AIR #2495
Old 08-14-2004, 08:02 PM   #3
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Plumbers putty ... easy to install ... and fun to work with.
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 08-14-2004, 08:21 PM   #4
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks guys.
Some where in the back of my head I remember sometimes your not supposed to use plumbers pudy because it reacts to certain surfaces.
I just wanted to make sure it was alright to use on my shower pan.
-Tim
Old 08-15-2004, 06:16 AM   #5
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
And don't forget to use the Friction Ring between the rubber gasket and the big jam nut. This lets you tighten the nut without binding it against the nut and rubber gasket.
Some plumbers will use a silicon sealant now a days as it does seal better and will last longer than the putty. The problem is they don't have the time to let it set up for 24 hours before attaching the rest of the drain piping. They will use silicon more frequently during new construction as they are not on the clock as they are in residential repair.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 08-15-2004, 04:21 PM   #6
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Well.... I guess I should have asked this first.
How do you remove it to reseal it?
There is a panel on the bottom that gives me access to the drain trap, but there is not much room to work down there.
Does the drain unscrew from the top somehow?
-Tim
Old 08-15-2004, 11:18 PM   #7
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Bumping this to the top....
Does anyone know how to remove the shower drain?
Thanks.
-Tim
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
Shower Drain Dbraw Sinks, Showers & Toilets 1 03-12-2003 10:59 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
