Literally This thing is awesome, I've never used a stinky slinky and I never plan to (this is my first RV and first time dumping). The sewer solution worked great, easy to use, easy to see when the tank is empty, easy to clean, and easy to stow, with no mess. Very nice. Worth every penny.
Thank you to those of you that have recommended it, it worked as advertised
I do carry a 10 foot section of slinky in case I need to use the type of dump that you are referring to. In over two years, I have yet to break out my "emergency slinky".
Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Without a doubt this is the biggest waste of time and water I have ever seen.
First off how do you know when the tank is empty since you are filling it while it is emptying? Second who thinks sending a small redirected stream of water up a 3 in pipe and around bends is going to have any effect in the tank itself.
Most campgrounds are on a well and a pump on demand system for their dump stations. I can just imagine what the campground thinks of this idea let alone those campers behind you in line.
The system I use is to dump the black tank first and as the flow slows I lift the slinky to a height just above the holding tank and open the gray water valve for about 5 seconds. This forces a LARGE QUALITY of water back into the black tank. I then close the gray valve and drop the slinky to finish draining the black tank. Once that has drained I close the black valve and open the gray.
I've read about these & think I understand the principle, but I am wondering what you do at a site where you have sewer hookups when it comes to dealing with your gray water.
Do you just leave your gray water valve open as you normally would and the gray water runs thru the device without the need to inject pressurized water, or do you leave the gray water valve closed, let it build up in the gray tank, and then dump it using the injection system the same as you would do for the black tank.
If you need to do the latter, it seems that would be a bit of an added inconvenience, no?
I must admit I've never had much problem with a "slinky" and perhaps one of the reasons is that from day one, I established a house rule that we only use the rv toilet for "peeing" in!
Course if we ever decided to try boondocking, I guess I'd have to revise the rules, unless there was a Macdonald's nearby!
The Sewer Solution DOES NOT spray the water back into the tank. It sprays down through the venturi of the SS unit to break up the waste. It is basically a water powered mascerator. I can tell when the black tank is empty when stuff stops coming out. The Sewer Solution dump hose is self cleaning with its own sprayer. No gray water is required to rinse the hose. I have found that I use less water with the Sewer Solution than I did with the sloppy stinky slinky.
Brian
re: "how do you know when the tank is empty since you are filling it while it is emptying?" -- because you don't do this.
The device is essentially a macerator pump that uses a jet of water to break up sludge and blow it down a 3/4" hose. It doesn't use all that much water and you can tell when it's done when there isn't any more sludge going down the pipe. For the gray tank, you can shut off the water supply and just let it drain as the gray tank doesn't need the macerating option - it may need the pump action, though. The SS is a good solution if you have to get your waste uphill a foot or two or over a bit of distance (usually home dump problems, not commercial).
The Sewer Solution can also serve as a tank rinse. These are built into many modern RV's but older ones usually don't have an external hose access to the black tank for this. Some homebrew equivalents used a fixed nozzle but the SS provides a lever so you can direct the jet down the pipe as a macerator pump or up the pipe as a rinse.
After you dump and rinse the waste tanks, consider putting a gallon or two of water in them to slosh around while they are empty and keep things from drying out.
You obviously have no clue what you are talking about with regard to the Sewer Solution. You can quite clearly see when the tank is empty because the main fitting of the unit is clear. When dumping the sewer solution shoots a stream of water into the discharge hose, not back into the tanks. You can direct the stream back into the tanks if you want after most has drained, but not when you are dumping. I don't know how long it takes you to dump, but I did both tanks in about 5 minutes.
Having reread the manufactures web page I think I will stick to my statements.
Howie, the part that connects to the sewer pipe on the airstream is clear plastic. You can physically see when the tank is empty. You can shoot water back into the tank if it is a clear shot, but you dont do this while dumping, you do it after the tank has emptied if you want to. I just use the black tank flush fitting on my airstream. The thing works, and works well in my opinion. It isn't messy and I don't have to fool around with a huge slinky hose.
Brian.
Edit: the red part in their diagram on their webpage is actually made of clear plastic (at least mine is--I got it at camping world)
