Old 10-26-2011, 01:55 PM   #71
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Yes, black 1st, gray last... If the sewer inlet is lower than the outlet on your Airstream, you could drain the gray by gravity alone but the siphon action of the water jet may shorten the drain time. I'm completely satisfied with my SS, but I also understand and accept that it takes longer to dump with the Sewer Solution than with the slinky. The SS is really useful when the sewer inlet is uphill from your trailer outlet since it would not be possible to dump in that situation with just the slinky.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 10-26-2011, 02:19 PM   #72
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by CallDon View Post
Since the usual procedure is to dump black first then grey, is that what you do with the SS? Do you use water pressure when dumping the grey??
The "standard" method is to dump black first then grey. It is common belief that the grey will flush out the more nasty black "stuff" from the hose and help push it down the line in the standard flex hose setup. In the SS, at least this is what I do, I leave my grey line open all the time to drain with gravity flow out the small diameter line. My grey really never should have any large materials to clog the line. I can then shot the SS jet down the line when I want to flush it. When I'm ready to dump the black I close the grey off and open the black with the water jet going. It pushes and shreads all black materials down the line. Cleanup is simple, close both black and grey valves and shoot the jet back up towards the valves and rinse, then flush that water too.
One thing to remember. Without a valve open there is no vent to the SS chamber area, rinse water will not drain properly. You have to open the grey valve to allow air to flow from the trailer tank vent. This will allow all liquids to drain through the line.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 03-21-2012, 09:46 AM   #73
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Lesson Leaned: This may be already mentioned in here somewhere, but - I used my Sewer Solution for the first time this past weekend. Worked great with one exception. When I directed the water flow up into the tank it forced some rather nasty stuff up thru my shower drain. Of course I did not find it until after I was all finished, cleaned up and making one last pass thru the interior to make sure everything was ready to go. I had several cups of liquid with a bit of solids in the shower floor. Cleaned it up and after several days I still have the stink stuck in my nose. The lesson learned was to either donít direct the water up into the trailer or remember to plug securely the shower drain from the inside. The trials and tribulations of a new vintage Airstream owner continue.
MICHAEL
Old 03-21-2012, 07:21 PM   #74
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by ROBERT CROSS View Post
Been pondering the SS for some time now, but we are "dockers" at heart and most of the stations we frequent do not have city water pressure. Seems it wouldn't perform nearly as well under those conditions. May be something to consider for home use though, that way we could avoid the Sunday evening rush at the DS.
My considering has ceased...put the dumper right next to the pad, no more lines at the CG and good water pressure to flush with, SS still on CW's shelf.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-21-2012, 09:08 PM   #75
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
What is the difference between the SS and a macenary pump that attaches to the sewer for doing the same thing and they are usually cheaper.
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline   Reply With Quote
Old 03-21-2012, 10:26 PM   #76
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I'm not familiar with a macenary pump.
The only alternative to the Sewer Solution that I am aware of is a macerator pump. These use an electric grinder pump as opposed to the Sewer Solution's water pressure/venturi system. The macerator pumps start around $350.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 03-21-2012, 10:53 PM   #77
Southwestern , Ohio
Originally Posted by moosetags View Post
I'm not familiar with macenary pump.
I think macenarys are hired guns that work for companies like Blackwater. . .
Nuvite-F is offline   Reply With Quote
Old 03-22-2012, 05:59 AM   #78
casa3805's Avatar
Corpus Christi , Texas
Images: 41
My only negative with the ss is that it is slower than the slinky. We love the way it works and the ability to flush and clean the lines is nice. But when in line at a dump station you will definitely slow other folks down, and you will be occupying the wash down hose as well. All in all, well worth the single negative.
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 03-22-2012, 06:08 AM   #79
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
I just love the SS idea; however, I'm slow to jump into the frenzy. Two Airstream friends have purchased the system and I'm very interested to see how it works out for them over the long haul. I guess I just figure if it's not broken don't try and fix it as the old slinky hose works just great for me under all conditions. Time will tell so keep posting friends and thanks.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-22-2012, 09:45 AM   #80
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
ur thinkin of Mercernary's and yes I mispelled the other.
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
Old 03-23-2012, 10:01 AM   #81
denellen's Avatar
2007 25' International CCD
1964 19' Globetrotter
2012 Interstate Coach
vero beach , Florida
Made me laugh.
Tnx: Dennis
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is offline   Reply With Quote
Old 03-23-2012, 10:09 AM   #82
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
I have had a sewer solution for five years. I bought it so that I could pump out the AS tanks at home. I have a 1/2 bath in my garage. I pump the tanks to the toilet in the half bath in the garage when needed (long lines at dump station or tank maintenance). I don't see the ss as a good alternative to normal dumping with a stinky slinky at a campground. It is slow and uses too much water for the process.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 03-23-2012, 12:26 PM   #83
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
Thumbs up Another SS Testimonial
We have used the SS for about a year. We have a 2007 19' Bambi. It has worked very well, and I would highly recommend it.
We carry a slinky and use it when a threaded hose connection is not available (usually at state or national park campgrounds). We have a "water theif" but have not used that yet. I would also use the slinky if there were water conservation issues; the SS does use more water.
After the tanks are empty, I routinely rinse them out with the SS (by rotating the nozzle to direct the water jet up into the drain). Our black tank has a flush feature, but the gray tank does not. Flushing the gray tank usually clears out dark debris that accumulates (or grows?) there. This is a great feature.
We use a 45 degree clear elbow, which makes attachment and removal easier. The only complaint is that the plastic quick-release on the check valve (where water supply hose attaches) has become difficult to connect and disconnect. I plan to replace with a brass unit soon.
We have a second 10' hose, but used only once (when I parked 2" too far from drain and was too lazy to move!).
aircampr is offline   Reply With Quote
Old 04-16-2012, 01:24 PM   #84
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Lafayette , Louisiana
I bought a ss from cw a couple weeks ago. I then ordered what I thought was the correct addapter to use it on my 1994 30' Excella. Back to the drawing board. The addapter is to small to go on my AS sewer outlet. Originally ss told me that cw sold the addaptor and even gave me a cw catalog #7131 that is supposed to be Valterra TO5-2285VP. The cw parts guy looked at me like I had two heads. Any suggestions?
jrkeef is offline   Reply With Quote
Sewer Solution Dieselgrin Waste Systems, Tanks & Totes 3 01-31-2009 07:35 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Sewer Solution Foiled Again Waste Systems, Tanks & Totes 14 01-07-2006 12:19 PM
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 07:05 PM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
