Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 09-10-2009, 11:11 AM   #1
Airstream01's Avatar
Profile:  2008 25' Safari FB SE
Virginia Beach , Virginia
Sewer Solution is the poop.
Literally This thing is awesome, I've never used a stinky slinky and I never plan to (this is my first RV and first time dumping). The sewer solution worked great, easy to use, easy to see when the tank is empty, easy to clean, and easy to stow, with no mess. Very nice. Worth every penny.
Thank you to those of you that have recommended it, it worked as advertised
Airstream01 is offline   Reply With Quote
Old 09-10-2009, 12:47 PM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
I've been using the Sewer Solution for over two years, now. I could not agree more.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 09-10-2009, 01:52 PM   #3
Profile:  2008 23' International CCD
golden , Colorado
I've seen a handful of dump stations where the rinse hose is not threaded. How does this work in that case or do you go back to the "stinky slinky"?
1cericks1 is offline   Reply With Quote
Old 09-10-2009, 02:10 PM   #4
moosetags's Avatar
I do carry a 10 foot section of slinky in case I need to use the type of dump that you are referring to. In over two years, I have yet to break out my "emergency slinky".
Brian
Old 09-10-2009, 02:34 PM   #5
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
I've seen that more often than not.
Old 09-10-2009, 02:49 PM   #6
moosetags's Avatar
I cheat. I carry a 'water thief' and a couple of plastic hose repair ends for such occasions.
Brian
Old 09-10-2009, 03:04 PM   #7
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Without a doubt this is the biggest waste of time and water I have ever seen.
First off how do you know when the tank is empty since you are filling it while it is emptying? Second who thinks sending a small redirected stream of water up a 3 in pipe and around bends is going to have any effect in the tank itself.
Most campgrounds are on a well and a pump on demand system for their dump stations. I can just imagine what the campground thinks of this idea let alone those campers behind you in line.
The system I use is to dump the black tank first and as the flow slows I lift the slinky to a height just above the holding tank and open the gray water valve for about 5 seconds. This forces a LARGE QUALITY of water back into the black tank. I then close the gray valve and drop the slinky to finish draining the black tank. Once that has drained I close the black valve and open the gray.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 09-10-2009, 03:15 PM   #8
moosetags's Avatar
The Sewer Solution DOES NOT spray the water back into the tank. It sprays down through the venturi of the SS unit to break up the waste. It is basically a water powered mascerator. I can tell when the black tank is empty when stuff stops coming out. The Sewer Solution dump hose is self cleaning with its own sprayer. No gray water is required to rinse the hose. I have found that I use less water with the Sewer Solution than I did with the sloppy stinky slinky.
Brian
Old 09-10-2009, 07:53 PM   #9
You obviously have no clue what you are talking about with regard to the Sewer Solution. You can quite clearly see when the tank is empty because the main fitting of the unit is clear. When dumping the sewer solution shoots a stream of water into the discharge hose, not back into the tanks. You can direct the stream back into the tanks if you want after most has drained, but not when you are dumping. I don't know how long it takes you to dump, but I did both tanks in about 5 minutes.
Old 09-10-2009, 03:13 PM   #10
Wingeezer's Avatar
Profile:  2005 30' Classic
Burlington , Ontario
I've read about these & think I understand the principle, but I am wondering what you do at a site where you have sewer hookups when it comes to dealing with your gray water.
Do you just leave your gray water valve open as you normally would and the gray water runs thru the device without the need to inject pressurized water, or do you leave the gray water valve closed, let it build up in the gray tank, and then dump it using the injection system the same as you would do for the black tank.
If you need to do the latter, it seems that would be a bit of an added inconvenience, no?
I must admit I've never had much problem with a "slinky" and perhaps one of the reasons is that from day one, I established a house rule that we only use the rv toilet for "peeing" in!
Course if we ever decided to try boondocking, I guess I'd have to revise the rules, unless there was a Macdonald's nearby!
Thanks, ............. Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-10-2009, 03:25 PM   #11
Profile:  1975 29' Ambassador
Reno , Nevada
re: "how do you know when the tank is empty since you are filling it while it is emptying?" -- because you don't do this.
The device is essentially a macerator pump that uses a jet of water to break up sludge and blow it down a 3/4" hose. It doesn't use all that much water and you can tell when it's done when there isn't any more sludge going down the pipe. For the gray tank, you can shut off the water supply and just let it drain as the gray tank doesn't need the macerating option - it may need the pump action, though. The SS is a good solution if you have to get your waste uphill a foot or two or over a bit of distance (usually home dump problems, not commercial).
The Sewer Solution can also serve as a tank rinse. These are built into many modern RV's but older ones usually don't have an external hose access to the black tank for this. Some homebrew equivalents used a fixed nozzle but the SS provides a lever so you can direct the jet down the pipe as a macerator pump or up the pipe as a rinse.
After you dump and rinse the waste tanks, consider putting a gallon or two of water in them to slosh around while they are empty and keep things from drying out.
Old 09-10-2009, 10:40 PM   #12
modarch's Avatar
Profile:  1967 17' Caravel
Memphis , Tennessee
My buddy has a '65 Safari with a custom built grey + black tank and swears by the SS. I have a '67 Caravel with the original sized black (only) tank. I would go with a SS, but am a bit worried about not having the "gravity" effect that is supposed to totally evacuate the tank when you release the valve w/ a full tank and let the black water flow into a stinky slinky. I guess rotating the SS valve and utilizing the flush feature will discharge any remaining solids, but I am still not sure about it. Also- on the mid-'60's Caravel, the toilet flange is just offset of the tank drain, so if I used the rinse feature of the SS, is it going to shoot stuff to the underside of the toilet valve??
modarch is online now   Reply With Quote
Old 09-11-2009, 11:46 AM   #13
Distantdrummer's Avatar
Profile:  1975 31' Sovereign
, various
What about the durability of the SS?
I see they offer a replacement pump. How often and why is replacement needed?
Whats at the end of the 3/4 inch discharge hose? Do you just drop the hose itself into the dung-hole at the station? Any prob with it "whipping" out and doing the "funky cobra" dance?
Any leakage at the (bayonet) connector during use?
Oh and what is a "Water Thief" ??
thanks
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 09-11-2009, 11:52 AM   #14
I can't comment on the durability as I haven't had mine very long, but there are no moving parts per se. The pump is a water jet pump. The only reason I think you'd ever need a replacement pump is if you dropped it or broke it or something. At the end of the hose they supply you with both a 3" and 4" adapter to fit snugly into the "poop chute" of the dump station, so no worries about it coming out and spraying you. I have no idea what a water thief is?
Sewer Solution Dieselgrin Waste Systems, Tanks & Totes 3 01-31-2009 08:35 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 11:23 AM
Sewer Solution Foiled Again Waste Systems, Tanks & Totes 14 01-07-2006 01:19 PM
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 08:05 PM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 06:43 PM
