Old 11-30-2014, 10:21 PM   #1
1999 25' Safari
Carlsbad , California
Sewer Solution Extension Question
I recently purchased a Sewer Solution and need to run it about 30' to the sewer line. I was going to purchase a 25' 3/4" hose, but do not see how to connect it to the PVC fixture on the end of the 10' hose that comes with the Sewer Solution. Any suggestions?
Jfuller678 is offline   Reply With Quote
Old 11-30-2014, 11:20 PM   #2
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I purchased two additional 10 foot sections from sewer solutions , and they connect together well.
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 11-30-2014, 11:31 PM   #3
2007 22' International CCD
Or you can use standard 1" PVC pipe and fittings to extend it. Lots cheaper. Put in fancy union fittings or just glue it together and cut it up afterward. Their extension is a bit pricy for what it is...
KE4GNK/AE
Old 11-30-2014, 11:35 PM   #4
They also make PVC hose adapters. A few other standard PVC fittings to adapt from the 1" stuff on the sewer solution to the 3/4" ID of the adapter, and you have it. Browse the PVC pipe and sprinkler fitting aisle of the local big box home center for inspiration.
You can build darn near anything with PVC fittings and glue, IMHO
KE4GNK/AE
Old 12-01-2014, 04:05 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use 1" PVC pipe and connectors to extend mine. Didn't even bother glueing them together. Works great. IIRC I had about 40' of pipe to get from where the 5'ver was parked to the sewer clean out we use for dumping.
Aaron
WBCCI #XXXX AIR #2495
Old 12-01-2014, 10:01 PM   #6
1999 25' Safari
Thanks for your input. I ended up cobbling together a PVC fitting and used 1" PVC. I was going to use 1 1/4" ID tubing so I would be able to carry it with me, but at $3.75 per foot I decided I would just camp within 10' of the sewer while on the road.
Old 12-02-2014, 03:56 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I very seldom am more than 5' from the sewer hookups in most campgrounds, quite often more like 3'. I suppose you could cut the PVC in half and carry some 5' sections and a couple of connectors.
Aaron
Sewer Solution 10' extension hose. Will_Brule Waste Systems, Tanks & Totes 1 09-07-2013 04:55 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 07:05 PM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
"sewer solution" Chuck Waste Systems, Tanks & Totes 17 08-29-2002 09:17 AM
