Old 01-07-2006, 12:19 PM   #15
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
I have had the Sewer Solution for three years and love it. The initial problem I had was with the connection. The Airstream had the Thetford bayonet connection and it was too large for the SS. I went through 3 adapters all of which failed because they are made of flimsy plastic and the ears would break off. I finally did the intelligent thing and bought a standard bayonet, sawed off the Thetford connector and glued the standard connector on. It works great.
I do not see the wisdom of not using the water hose for the whole dumping process. It forces a thin stream of water into the ouput hose and acts as a mercerator. It also keeps any fluid from contaminating the quick connect point.
One of the great things about the SS is that that highspeed stream of water can be pointed up into the discharge tube and cleans it and the sliding valve. In fact it forces water into the tank which flows back out when the stream is redirected out the hose. You can see a lot of stuff flowing out that would have been left by not performing this one little task.
By letting the water run for a few seconds after the tanks are empty flushes the hose and keeps things relatively sanitary. One does not get ones hands dirty and there is no odor to contend with.
I bought the 10 foot extension hose and have not had a case where I could not reach the ground dump. There have been cases where, without the extension, that would have happened.
I have never been to a dump station that doesn't have a water supply so I have not encountered that problem.
All in all, it is a sound investment. My only complaint is that the output hose is very tough and when coiled resists being forced into the hose compartment in the rear bumper. I reminds me a little of trying get an unruly child into the bedroom with arms and legs splayed out catching on everything in sight.
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
Sewer Hose length? AirHog Waste Systems, Tanks & Totes 16 04-21-2004 01:39 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 08:49 AM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
