Old 08-29-2002, 10:47 AM   #1
tomb's Avatar
Images: 8
Sewer Solution
that goes from ears to hose ...i need to go from the larger lugs on thetford to the smaller ears on sewer soultion...any ideas????
TOM BOONE 1987 SOVEREIGN 25' WBCCI#14120
tomb is offline   Reply With Quote
Old 08-29-2002, 12:30 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Is this what you need?
http://www.campingworld.com/browse/s...44&skunum=7131
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-29-2002, 01:16 PM   #3
tomb's Avatar
Images: 8
SEWER SOULTION
just went and looked at a mess of fittings,including the oart you shoe above....that gets me from the trailer to a hose..i need to go from trailer to the sewer solution...a fitting that has the thetford ears to fit trailer on one end and standard nobs,studs,tats or lobes to fit ears on sewer soultion....this make any sence ??????
Old 08-29-2002, 06:15 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I think the part that Brett showed is the correct part. The end with ears fits the larger Thetford fitting on your trailer. The opposite end has 4 studs that fit the ears of your sewer solution. I know that Camping World has the proper part because I purchased one from them several weeks ago. They also have the Valterra part that fits the Thetford fitting then reduces so that you can put a 3" hose on it. It is hard to see the studs in the picture but if you look close enough you will see them. I had to buy this adapter so that I could add a 45 degree clear elbow for mounting of a Flush King I also purchased several weeks ago from CW.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-29-2002, 06:43 PM   #5
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Arrow
When I posted the pic (blatantly copied from the CW Site) The 4 little nubs seemed more prominent on the monitor I have at work. The link says it is the thetford to valterra converter and it looks like the one I used to have when I used a flushing tool on my 77 center bath Soverign.
Brett G
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 10:09 AM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 02:49 PM
