Old 06-01-2015, 03:29 PM   #1
1977 23' Safari
Carberry , Manitoba
Sewer outlet 78 Safari
My Safari sewer outlet is routed through the frame channel. It is 3.5" poly and I have bought a black poly fitting that accepts a standard drain hose fitting. Originally, there was a plastic piece that slid over the 3.5" pipe up against the frame to cover the unsightly sort of round cutout that allows the pipe through the frame. Unfortunately 40 years of sunlight made this piece so brittle it fell apart upon removal of my tanks and outlet drain. Any idea where I could get some sort of replacement fitting? It is really only aesthetic, it doesn't do anything except give a finished look to where the pipe comes through the frame. The original appeared to be white/cream colored plastic but I'm not fussy what color a replacement is. TIA Lorry
cp1977 is offline   Reply With Quote
Old 06-01-2015, 04:43 PM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I need one too, for my 77 safari, hopefully someone will post a source
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 06-03-2015, 04:04 PM   #3
1977 23' Safari
Carberry , Manitoba
I'm going to try mixing up some home made sugru and see if it can be tooled smooth enough to look ok. Its not like anyone but me is going to be getting close up and personal with it. In any case, I have a whole tube of opened silicon and a box of corn starch to mess around with.
How To Make Your Own Sugru Substitute
Converter outlet plug bad? 1997 Safari caseypris Electrical - Systems, Generators, Batteries & Solar 7 10-01-2012 05:37 AM
trouble hooking up waste water outlet to sewer hose Molly1973 Waste Systems, Tanks & Totes 9 05-21-2012 06:38 AM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Exterior outlet on '04 Safari DJW Electrical - Systems, Generators, Batteries & Solar 6 01-23-2011 07:17 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
