Old 02-20-2009, 09:05 PM   #1
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
Question Sewer Hose won't connect
I have bought 2 or 3 sewer hoses now! I am unable to find a sewer hose that will connect I have a 72 AS with the thetford dumpvalve any help would be great!
shermantic is offline   Reply With Quote
Old 02-20-2009, 09:15 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You will need to buy a Thetford connector for your sewer hose. It will be white in color. The black or red connectors will not go onto a Thetford connector.
You can buy an adapter that will allow you to connect those other connectors to the Therford connector on your Airstream.
I have never seen a sewer hose come with a Thetford connector.
Old 02-20-2009, 09:22 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You need to get a sewer hose connector that is Thetford. Most of the hoses connectors that you find will be Valterra which are almost the same size. Camping World and other major RV supply stores carry Thetford fittings
Richard
Old 02-21-2009, 12:04 AM   #4
1960 22' Safari
in the wilderness , The great Mojave Desert
You need the Handymans secret weapon. Duct Tape.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 02-21-2009, 12:27 AM   #5
Kevin245's Avatar
Correct...Just don't expect it to stay white.
I never did understand the color choice, but it works.
William C. Swinney
Old 02-21-2009, 08:33 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The Thetford part is called a "Universal" adapter or connector. They are cheap. I semi permanently attached mine to the dump valve with vulkem
Old 02-24-2009, 02:39 PM   #7
1975 31' Sovereign
Ladysmith , British Columbia
sewer hose
I had the same problem and I got a tetford but with a 3" end so it could fit the hose.I'm considerering changing the whole connector to up grade it to todays standered.It sems to be only a hose connector in the bumper panel.This will eliminate buying expensive tedford parts.When putting the hose on I pulled out a portion of the wire in the hose and that allowed easer fitting of the hose.Hope this helps.
Dave LeClair is offline   Reply With Quote
Old 02-24-2009, 02:56 PM   #8
soldiermedic's Avatar
Florissant , USA
I had the same issues with my 75.
You need this part from Vintage Trailer Supply.
Thetford to Valterra Connector.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-24-2009, 07:21 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
In case I wasn't clear above there is an adapter to go from Thetford to Valterra. It's cheap. It just snaps on like a regular connection. Soldiermedic is also talking about the same part. You don't have to change anything else, unless you want to.
Old 02-24-2009, 10:39 PM   #10
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Order them today
Old 02-24-2009, 11:07 PM   #11
gail's Avatar
2017 16' Sport
Malibu , California
We had to buy the white color connector at an airstream dealer
gail is offline   Reply With Quote
sewer hose adapter ericwarren Waste Systems, Tanks & Totes 18 10-16-2008 06:52 PM
Sewer Hose Adapter kjj422 Waste Systems, Tanks & Totes 12 07-23-2008 12:28 PM
sewer hose john roeder Waste Systems, Tanks & Totes 5 04-23-2007 07:04 AM
Sewer hose mpumphrey04 Waste Systems, Tanks & Totes 2 11-30-2005 09:18 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 09:49 AM
