Old 05-16-2014, 05:31 PM   #1
2014 27' FB International
Macon , Georgia
Sewer Hose Problem
My 27FB International has a short 46 inch long storage tube mounted underneath. I can't find a hose longer than 10 feet that will fit in it when the hose is collapsed. The heavier duty hoses like the Viper and the Rhino won't even fit at 10 feet. I really want to use the storage tube if possible. Any suggestions?
Roadtech is offline   Reply With Quote
Old 05-16-2014, 11:08 PM   #2
2004 16' International CCD
Chicagoland , Illinois
I'm not trying to be a smart-azz, but you might replace the short pipe with a longer one and/or add another section of pipe if there is room.
The other option would be to abandon the older-style hoses and switch to something like the Sewer Solution.
Amazon.com: Valterra SS01 Boxed SewerSolution System: Automotive
Amazon.com: Valterra SS02 Green 10' Extension Hose: Automotive
With the Sewer Solution you could probably cram quite a bit more hose into your tube?
Airrogant is offline   Reply With Quote
Old 05-16-2014, 11:18 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have never used that tube; I keep my sewer hose in my rear bumper storage compartment.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-17-2014, 12:01 AM   #4
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
My storage spaces are a lot different but the Sewer Solution works great and several of the pick-up gang of NorCal Airstreams use it. I'm not sure where they store them but it doesn't take up much space, as the Amazon link shows.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 05-17-2014, 02:21 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Sewer hose storage
I also use the Sewer Solution and like it very much. If I was going to stick with a traditional sewer hose, however, I would replace the relatively short four inch tube under the trailer with a longer six inch one. That should hold just about any of the higher end sewer hoses without too much trouble.
Bob Martel
WBCCI# 5766
Old 05-17-2014, 05:19 AM   #6
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We use the EZ Coupler hose kit. Two 10 foot sections of hose, each collapses down to under 40 inches. Two sections fit in the storage tube on our 2014 Sport 22FB.
Cannonball is offline   Reply With Quote
Old 05-17-2014, 06:36 AM   #7
Macon , Georgia
Where do you keep your power cord? I keep mine in the rear bumper compartment.
Old 05-17-2014, 06:46 AM   #8
Chelsea , Michigan
Images: 12
If your rear bumper storage area is like mine, it gets wet back there, probably not a good place for your power cord. I keep mine in the front locker (FB unit)
Bob Martel
WBCCI# 5766
Old 05-17-2014, 10:14 PM   #9
Salem , Oregon
Images: 18
Hi, I keep my power cord, water hoses, dog bone adapters, spring bars, torque wrench, breaker bar, with sockets, and a few more items in my storage compartment. Mine is located on the rear street side, under my queen bed.
In my rear bumper storage compartment, I keep my sewer hose, sewer gloves, [electrician high voltage gloves] spare sewer adapters, porch mat, and my awning tool.
2005 Safari 25-B
Old 05-18-2014, 05:25 AM   #10
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
We were able to make a 15' Rhino work by shortening the hose by a foot or two.
teagues is offline   Reply With Quote
Old 05-18-2014, 06:44 AM   #11
Macon , Georgia
Wow, the simplest solutions are always the best. Thanks.
Old 05-18-2014, 07:43 AM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would lengthen the storage tube. I like being able to slide a full length heavy duty hose with the trailer side fitting attached right into the tube near the sewer connection. One of the better attachments we have put on our Airstream.
Old 05-18-2014, 08:35 AM   #13
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Has anybody replaced the tube with a larger diameter? I'd love to use it, but the fittings on the heavier hoses don't fit.....at least they didn't fit in the tube on our 23fb. I haven't tried the tube on the. 25fb, but I assumed it was the same size. As it is I keep the sewer hoses in the bumper trunk and nothing else. I didn't like the idea of mixing anything with the sewer hoses.
Landrum is offline   Reply With Quote
Old 05-18-2014, 08:45 AM   #14
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I added a second longer hose storage tube underneath next to the Airstream supplied tube. It was an easy job and is plenty long enough for my longer sewer line. I use the short tube for fishing poles.
http://m.campingworld.com//shopping/...er-black/60174
kscherzi is offline   Reply With Quote
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Sewer Hose Questions (peww) overlander76 Waste Systems, Tanks & Totes 28 06-09-2007 10:01 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 08:12 PM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
