Old 04-13-2016, 11:39 AM   #1
2013 28' International
Bozeman , Montana
Sewer hose fell out or was misappropriated
At the end of our last trip we rolled into the campground and found the sewer hose storage cap hanging by the tether and the hose MIA. We had stopped for the afternoon at a hot springs and the trailer was parked in less then great spot. There were many signs saying not responsible for theft from vehicles, etc.
So, I don't know if someone actually misappropriated the hose or the cap came open going down the road and the hose fell out. We were on some really crappy roads so I'm guessing that is possibly and I can't imagine someone taking an old sewer hose, yuck.
Has anyone had problems with the storage cap coming off going down the road? Any good solutions to make sure it does not come loose short of a piece of tape?
Also, I'm buying a new hose and fittings and don't remember if the one from Airstream had an angled end that connects to outlet or if it was straight. It worked fine for me whichever one it was so I'd like to order the same.
Thanks!
HeadWest is offline   Reply With Quote
Old 04-13-2016, 11:43 AM   #2
SteveH's Avatar
Common Sense , Texas
I've lost one on the road also, and feel sure it was not stolen. "Stuff" happens.
Regards,
Steve
Old 04-13-2016, 11:50 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If someone stole a used sewer hose, shame on them. Like you said...YUKKK!
A number of years ago we were pulling Old Lucy down the road. I happened to take a glance in the driver side rear view mirror and saw the greater portion of my bright red slinky dragging along the road. One end was still in the tube. I was able to stop pretty quickly and put things back together. It had been dragging for a while as the end was pretty torn-up.
If I had not taken a glance when I did, I'm sure that slinky would have been history. The cap on my storage tube was tight, so I am guessing that I had failed to close it properly.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 04-13-2016, 12:19 PM   #4
Lily&Me's Avatar
Normal , Illinois
Have lost several in just this way over the years.
Maggie
Old 04-13-2016, 12:34 PM   #5
2005 30' Classic
Burlington , Ontario
Hmmm, never happened to me ..... yet ..... but if it did, I guess my first thought to prevent a repeat would be to look at the possibility of drilling a small (1/4"?) hole on an angle through the cap and diagonally through the side wall of the tube when the cap is in the closed position, then finding some sort of locking pin through both holes so it couldn't rotate.
Alternately, if you have enough free space in the tube when the hose is in there, just a drill a hole right across the tube so you could put a securing pin or rod across so that even if the tethered cap comes off, the hose could not work its way out with the pin in place.
Brian.
Old 04-13-2016, 12:50 PM   #6
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Solution is duct tape. Silver so it matches the tow vehicle and the trailer. If you apply it correctly it pulls off your latex gloves so you do not have to touch them and keeps them flapping in the wind to remind you to reinstall the hose for the next sewer connection. Duct tape wraps up into a nice neat package to throw away. Just make sure to repeat the glove removal process or you have to wash your hands. Pat
Old 04-14-2016, 10:28 AM   #7
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I do have a suggestion to the question about an angled connection to the sewer hose connection. I bought a clear plastic angled connector, this allows me a visual on the emptying of the tanks. Makes life easy, not odor free.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-14-2016, 10:29 AM   #8
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
We have had the sewer hose storage cap open while traveling but we don't use it... too short.
I keep mine in the bumper storage with the flush hose since that compartment is stainless and drains.
I can't imagine someone stealing a sewer hose.
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance, Equalizer 1000, pulled by a 2018 GMC Sierra 1500 SLT 4x4, Crew Cab, 5.3L V8 ECOTEC3, 3.42 axle, 8 speed auto WBCCI #6111
beachbouy is offline   Reply With Quote
Old 04-14-2016, 10:51 AM   #9
1996 25' Excella
Tillsonburg , Ontario
If your hose was in a storage tube, then it likely did not have an angled head. I don't think the angle fitting will go into the tube.
I made my own storage tube using 4" PVC and used a loose fitting cap that was held in place by a 5" long bolt with a wing nut. If your cap continues to come loose consider a 5 "x1/4 or 5/16 bolt and drill the cap and tube so the bolt goes through both and fasten with a wing nut
JCW
JCWDCW is offline   Reply With Quote
Old 04-14-2016, 11:06 AM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Had it happen this summer. Hose dragged hard enough to pull loose the carrier. I saw that dragging and stoped. A car stopped and said they saw a run over hose a couple of miles back. Just put the replacement carrier on Tuesday. I have both the angled and the straight fitting. I much prefer the straight fitting.
Old 04-14-2016, 11:12 AM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A home-care nurse taught me the trick to removing dirty gloves when I was temporarily home-bound following surgery, and had to self-administer intravenous antibiotics— wearing disposable latex gloves.
Grab the right glove at the inside of the wrist with the thumb and index finger of the left hand. At the same time, grab the left glove at the inside of the wrist with the thumb and index finger of the right hand. Pull both hands apart while holding onto the gloves. If done properly, both gloves will end up inside out, one glove inside the other, and you never have to touch a dirty glove surface.
Cats and ultraleather Airstream upholstery don't mix!
Old 04-14-2016, 11:14 AM   #12
Coaster's Avatar
Saint Augustine , Florida
Our cap is so loose it won't stay on. At first I used a plastic toothpick, then I found a mini bungee cord . Problem solved, my hose never fell out, but when people beeped a few times I became aware of the issue.
Coaster is offline   Reply With Quote
Old 04-14-2016, 11:27 AM   #13
1974 Argosy 20
Kooskia , Idaho
The under the belly pan storage tube on my 20' FC has a white cap and a white end. It is very hard to see when they are properly aligned when fully closed. I put a piece of colored tape on mine between the fixed and movable parts, when I was sure I had it done right. I slit the tape with a knife and now when I put the cap on, I can easily see that it is properly aligned, and thus closed up right. When the cap is on right, there is no possibility of it coming off by itself, at least on the one on my rig.
A straight end is all that will fit into the tube on mine, no angled fitting will fit.
Old 04-14-2016, 11:40 AM   #14
Major Tom's Avatar
Yep it happened to me on my last trip. Not only did the hose bail out, but the wind ripped the plastic cap off as well. Lucky I had a spare hose in the outdoor storage compartment.
Major Tom is offline   Reply With Quote
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 08:12 PM
Cover for sewer hose fell off! Safari-Rick 2005 Safari 6 07-30-2005 09:27 AM
