Old 12-20-2012, 10:41 AM   #71
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Here is a link to SS video so you can see how it works
Old 12-21-2012, 11:33 AM   #72
Wild-Air's Avatar
2012 25' FB Flying Cloud
Minden , Nevada
Thanks for the Youtube link, Mo. It's an interesting contraption and it would be useful when needing to discharge uphill. I wonder if it would be something usable on a full-time basis.
Russ
Wild-Air is offline   Reply With Quote
Old 12-21-2012, 12:12 PM   #73
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I purchased a SS with optional hose yesterday to have as an "uphill" option in addition to a 6" piece of 3" clear pipe and put these in the rear bumper tray along with a 15' slinky with three 5' extensions.
The gotcha is having to have a close fresh water hydrant with good pressure to create the venturi action sucking stuff out of the 3" pipe and pushing it down the 1" hose. There are no moving parts in the end cap that attaches to the 3" pipe.
Old 12-21-2012, 01:31 PM   #74
flynaxos's Avatar
2008 25' Safari FB SE
Daphne , Alabama
I carry both the stinky slinky and the SS.
Airstreams are unique in that they are built closer to the ground than the SOB's. As a result, the sewer connections are lower to the ground. We have been in several campsites that have built-up sewer connectors and in some cases the stinky slinky won't work at all. Basic physics. It won't flow uphill.
Because of the "pump effect" created by the water inlet hose, the SS allows the waste to be "pumped" uphill. We have had as much as a 6 inch lift between our sewer drain and the campsite's inlet. The SS works beautifully in this environment.
Maybe it does flow uphill after all. Hmmm. . .
flynaxos is offline   Reply With Quote
Old 12-22-2012, 06:43 AM   #75
2011 30' Flying Cloud
Arvada , Colorado
After reading the many posts, I think my problem may be a lack of sufficient water pressure to move the waste quickly. And, that may be caused due to the two "Y" connectors I use between the faucet and the SS. I'll see how a new set up works next spring. i would prefer not to carry both, but right now my first choice is the Slinky.
Jack46 is offline   Reply With Quote
Old 12-23-2012, 08:24 AM   #76
switz's Avatar
2014 31' Classic
Images: 8
As a inexperienced owner reading the forums, I discover many items that others found were "useful" or "necessary" in their travels. I often elect to acquire some of these items for the piece of mind that it is aboard.
However, remembering where "it" is may be as much as a problem as the problem itself.
Old 12-23-2012, 10:27 AM   #77
r carl's Avatar
Lin , Ne
Originally Posted by moosetags View Post
One would think that a $70,000 RV would come with a sewer hose like it comes with a shore power cord. It's kind of like buying a new Cadillac, and then having to go to an accessory store and buy a steering wheel for it.
It doesn't really make any sense, but it's the way of the RV world.
Brian
Right when you are about to sign the papers for your new trailer, put down the pen and look at the salesman and ask if there is water and waste hoses in the camper. Im sure he will do anything at that point.
Old 12-23-2012, 11:02 AM   #78
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink If you think of it....
How to cut the problem in half......maybe.
If while "packing", instead of asking, "did we bring"....you make sure it's brought.
If it's your thought, it's your duty.
We were young and knew nothing...now we are old and everyone else knows everything.
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 12-23-2012, 05:47 PM   #79
1988 32' Excella
Robbinsville , New Jersey
You need to be careful picking out those "Y" connectors, the next time you go to a store with several different "Y" connectors look through them and compare the size of the openings in the valves, some are less then 1/4".
Wazbro is online now   Reply With Quote
Old 05-07-2015, 08:24 PM   #80
2015 16' Sport
Portland , Oregon
newbie help please... We almost picked up our new 16' today. Few issues still to be resolved. But anyway I bought the 15' Valterra Viper hose for the sewer and was unable to cram all of it into the storage tube under the trailer, nor could the technician doing our walk through. removed the cap, etc... What did I do/buy incorrectly?
thanks,
Lee
leedav is offline   Reply With Quote
Old 05-07-2015, 08:31 PM   #81
Lexington , Kentucky
We had the same issue. We ended up just storing the slinky (and two 5-foot extensions) in the rear bumper.
wlanford is offline   Reply With Quote
Old 05-07-2015, 08:35 PM   #82
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I'm not familiar with that specific hose, but I do believe a lot of the heavier hoses with large connectors simply don't fit in that tube. You have a few options:
1) get a hose with smaller connectors
2) Replace the storage tube. Valterra does make a larger sewer storage tube.
3) keep your sewer hose in your bumper trunk. Oh wait did you say Bambi? You may not have a bumper trunk.
4) make a custom storage tube......which is what I did. I bought a 5x5 black pvc fence post and mounted under the AS. I'm able to fit two of the nice hoses with all the connectors into my new storage tube.
5) look into the Sewer Solution, but this would only help if you ALWAYS have full hookups otherwise you will need a slinky as a backup.
Landrum is offline   Reply With Quote
Old 05-07-2015, 09:03 PM   #83
2015 16' Sport
Portland , Oregon
Thanks Landrum. We are having a bumper installed, but storage is so limited I'd hate to use it for the sewer pipe. Guess I'll get a shorter hose for the near term and upgrade the storage when I can get to it
Old 05-20-2016, 08:29 PM   #84
2015 23' Flying Cloud
Livermore , California
can someone point me to a thread that discusses how to set up a home sewer flush system? Not sure if you have to have a septic tank setup or not.
cactusjk is offline   Reply With Quote
Coupler issue. 05ModPod Hitches, Couplers & Balls 3 06-02-2011 06:15 AM
PVC cap for sewer hose? lovetofly Waste Systems, Tanks & Totes 2 05-29-2011 08:48 PM
Sewer Hose Holder Air Cruiser Waste Systems, Tanks & Totes 10 04-24-2011 01:48 PM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 08:50 PM
2011 International sewer questions AirEPotter Waste Systems, Tanks & Totes 12 02-19-2011 11:01 PM
