Old 06-28-2011, 08:19 PM   #15
2011 30' Flying Cloud
Arvada , Colorado
I tried a Sewer Solution and found that with my two dump pulls being located so close to the outlet, that I was not able to position the Sewer Solution cap in such a way as to allow for hookup of the water input valve? What did I miss??? We have a 2011 Flying cloud 30'
Thanks, Jack
Jack46 is offline   Reply With Quote
Old 06-28-2011, 08:36 PM   #16
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by Wingeezer View Post
I like to buy the best quality 3" hose I can find - thickest "mil" spec., as I have found the cheaper and thinner ones tend to develop pinholes quickly even from slight dragging on the ground.
Brian
Good point, Brian. I might get myself a backup hose to cover the pinhole issue and to have if I ever need that extension. A coupler will be on the shopping list, too.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 06-28-2011, 08:41 PM   #17
MrUKToad's Avatar
Chatham , Ontario
Incidentally, although they are not inexpensive, I also carry an extra 30 amp electrical extension for the same reason, as well as adapters that will allow me to plug into not only a 30 amp receptacle, but also 15 amp or 50 amp. I have had to use them all at one time or another!
Brian
Not strictly on topic but it's a good point; at Inverhuron Provincial Park, some of the electric cable runs were listed as being over 100 feet! No wonder some of the sites weren't booked. Perhaps I will be looking at a second 50' cord
Old 06-28-2011, 09:23 PM   #18
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Thanks, Jack
Try a right angle M/F bayonet elbow. This will put the SS horizontal just below the outlet. That will give you a better position to hook up the input hose.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-28-2011, 09:50 PM   #19
Mexray's Avatar
1978 28' Ambassador
Morada , California
Jack - did you know that the 'lever' in the SS can be assembled in the opposite position - swapping ends, as it were - if that would give you the room to operate it...
However, you should send it back to SS and let them do the modification...I did it myself, and it doesn't exactly line up properly and I had to do some filing inside to make it work right - a slight 'slip' with the drill could have messed up the main housing!
The instructions I got with my SS a few years ago mentioned that the user could do the modification...I called SS when the parts didn't line up properly when I reassembled it from the other end, and they said it wasn't field changeable currently and they would do it free, with the correct parts - I was leaving on a trip and so did it myself, but wouldn't again...
The SS is our ONLY solution when we have hook-ups...when boon docking, we still use the stinky slinky for those later quick dump station visits, etc...
Happy drains out there...
Ray & Pat; Morada, CA
Old 06-28-2011, 10:02 PM   #20
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Is the SS better than a 12v Macerator Pump?
Darkspeed is offline   Reply With Quote
Old 06-28-2011, 10:44 PM   #21
Kevin245's Avatar
I was a sewer solutions skeptic...that is until I tried one. Will never go back to the stinky slinky. We do keep one stored in the bumper as a backup.
Eleanor Roosevelt
Old 06-29-2011, 04:34 AM   #22
casa3805's Avatar
Corpus Christi , Texas
Images: 41
We bought the Sewer solution and it is very nice. It is slower than the slinky but really does a much better job I think. (You can actually force water back into the Black Water tank on ours) We do hang onto a slinky as backup, don't want to create a line at a dump station while we wait on the SS to work.
Jack 46. Our connection is in the back next to the bumper and I also could not get the hose inlet to fit. Bought a 6" clear extension for the dump connector and all is good.
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 06-29-2011, 05:10 AM   #23
Arvada , Colorado
Thanks, not enough clearance in any of the 90 degree positions, but an extension would surely work. Thanks for the tip. Jack
Old 06-29-2011, 05:21 AM   #24
Arvada , Colorado
Chuck/Skye, Where did you find the 6" clear extension? Does not seem to be available from Sewer Solution. Thanks. Jack
Old 06-29-2011, 06:40 AM   #25
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
At the risk of being on the bottom of the dog pile, I have to add another comment about a picture above. Mixing potable water and sewer connections is really a recipe for disaster. Fresh water filters and potable water hoses don't mix with the connections to the black and grey water tanks and the sewer. I believe the picture above is a case study in bad camp sanitation.
JBinKC is offline   Reply With Quote
Old 06-29-2011, 07:53 AM   #26
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
I agree with JBin KC. Unless a back flow preventer is used this is a possible disater in the making.
jkcru is offline   Reply With Quote
Old 06-29-2011, 08:34 AM   #27
Gainesville , Florida
Carry another hose for this. Clear connectors available at any rv store or some walmarts,AS dealers. jim
Old 06-29-2011, 10:22 AM   #28
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks, Jack
I have a 6" clear extension that I use to provide sufficient clearance.
Coupler issue. 05ModPod Hitches, Couplers & Balls 3 06-02-2011 05:15 AM
PVC cap for sewer hose? lovetofly Waste Systems, Tanks & Totes 2 05-29-2011 07:48 PM
Sewer Hose Holder Air Cruiser Waste Systems, Tanks & Totes 10 04-24-2011 12:48 PM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
2011 International sewer questions AirEPotter Waste Systems, Tanks & Totes 12 02-19-2011 10:01 PM
