Old 04-27-2015, 02:20 PM   #1
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Thumbs up Sewer Hose Adapter Size Problem
Hey guys, Been a longtime since I have been to the boards. (Technically, I suppose that is a good thing cause it means no problems) Anyway, I had an issue with my sewer hose adapter which is the original Thetford hose to my 1976 Argosy. I twisted on the adapter and crack! One of the 2 prongs that hold it secure snapped off. I went to the RV store and grabbed a new one but iwas just a hair too small (maybe by a millimeter or so) So then I did some research online and ordered this:
SmartDrain Sewer System
I got a great deal on it (half price) so when it arrived I was pumped. But guess what it was also shy by about a millimeter. Anyone have the story here? Did my pipes expand over time? Did they change the size? Does this have something to do with Valterra? I am at a loss...
Thanks for any and all help!
crabbey1 is offline   Reply With Quote
Old 04-27-2015, 02:30 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I had to use these on my Bambi II. They are cheaply made and easily break.
Amazon.com: Valterra T05-2285VP Thetford to Valterra Universal Adapter: Automotive
MICHAEL
Old 04-27-2015, 02:51 PM   #3
1974 Argosy 20
Kooskia , Idaho
Your Argosy has Thetford fittings, most RV's now use Valterra sewer connectors, including new Airstreams. You can get a Thetford to /Valterra adaptor (noted in AWCHIEF's post, or get an original Thetford at the RV store (they may have to order it, but they are available). To use the Sewer Solution you will probably have to use the adaptor.
Old 04-27-2015, 03:02 PM   #4
crabbey1's Avatar
1976 Argosy 22
Images: 33
So just to be clear idroba, you are saying that in order to use the Thetford Sewer Solution, you think I need to get a Thetford to Valterra adapter? I will give that a go and report back...
Old 04-27-2015, 03:23 PM   #5
1974 Argosy 20
Kooskia , Idaho
I just looked at the Thetford Sewer Solution link you posted and it is unclear if it uses the "old" Thetford system you have on the Argosy, or the much more universal (now days) Valterra system. I would expect it probably uses the Valterra system now. You might call them (web site has a support section) and ask them directly.
Even Sony which made the Betamax VCR finally gave in and started to make the VHS recorders, so at some point companies just switch over. And now, no one makes any VCR's at all! How the world changes.
Old 04-27-2015, 03:41 PM   #6
crabbey1's Avatar
1976 Argosy 22
Images: 33
Maybe someday we will have digital poop and Sony can start making those sewer hoses...
Old 04-28-2015, 11:05 AM   #7
1977 31' Sovereign
Lynnwood , Washington
I had a similar problem. Sewer fittings were very stiff after not being used all winter. I couldn't get them to connect without using a pair of strap wrenches. Here's what I did:
1) Leave fitting(s) out in the sun for a while and let them soften up.
2) Then apply a liberal amount of plumber's grease on both fittings.
Tom
TomKirk is offline   Reply With Quote
Old 04-28-2015, 04:12 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Crabbey1, yes, Thetford no longer uses Thetford bayonets, so you have three choices:
1) use the adapter
2) replace the end of the drain hose with an (old style) Thetford connector
3) replace the fitting on your trailer with a Valterra fitting, possibly also replacing the valve at the same time.
VTS has parts as do several other sources.
Thetford Valves & Fittings
Old 04-28-2015, 10:22 PM   #9
crabbey1's Avatar
1976 Argosy 22
Images: 33
Thanks guys. My adapter comes tomorrow.
Old 05-04-2015, 11:53 AM   #10
crabbey1's Avatar
1976 Argosy 22
Images: 33
After some issues with delivery via Amazon, my adapter arrived. I am happy to report that it fits perfectly and does exactly what I needed. Thank you all for the responses. Another crisis averted thanks to the helpful folks on the Airforums.
What size Sewer hose connection? 72Blazerod Waste Systems, Tanks & Totes 6 09-20-2015 10:12 AM
sewer adapter for 1988 25 ft Excella Airstream okeejohn Plumbing - Systems & Fixtures 6 08-04-2015 12:41 PM
Sewer Hose Problem Roadtech Waste Systems, Tanks & Totes 20 05-19-2014 08:43 PM
sewer hose adapter ericwarren Waste Systems, Tanks & Totes 18 10-16-2008 05:52 PM
Sewer Hose Adapter kjj422 Waste Systems, Tanks & Totes 12 07-23-2008 11:28 AM
