Old 10-16-2008, 03:12 PM   #15
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Tip.......
Drill some 1/2 holes in the tube caps and a few along the bottom of the tube.
After dumping, and washing out "slinky", all will be dry and much nicer to handle at the next use.
Old 10-16-2008, 05:07 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by purman View Post
Just go to the Home depot and buy some tubes and fittings make your own, at what ever size you want.... Mine fits just fine (with a mallet) Just can't figure out how to get it out yet....
Drill a hole in the end of the tube opposite the open end. Squirt some starting fluid in it, and apply a flame to the hole. You will not only get the slinky out of the pipe, it will blast the slinky clean, and get rid of your noisy neighbors for a while, if you aim it right.
Old 10-16-2008, 05:29 PM   #17
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Try this
My MH has a compartment for storing hose & connector. Maybe you modify one of your comprtment to accept this Airstream issued parts. The tube that holds the hose is the flexible aluminum dryer hose type. You might be able to slightly bend it to conform to your available space. The flexability of the slinky should folloe the curve of the dryer hose. Remember to have the capped end lower so the slinky run off doesn't end in your storage compartment. The handle can be replaced with a key locking device if you chose to mount this directly to the outside of your trailer.
ID:	69523   Click image for larger version
ID:	69525   Click image for larger version
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-16-2008, 05:29 PM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Easy. Just get a bigger mallet
Old 10-16-2008, 05:52 PM   #19
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
That almost sounds as fun as my potato gun which works on the same principal (but it much cleaner)
What if it is really stuck and back fires, man that could be a mess
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Sewer Hose Adapter kjj422 Waste Systems, Tanks & Totes 12 07-23-2008 11:28 AM
sewer hose john roeder Waste Systems, Tanks & Totes 5 04-23-2007 06:04 AM
Sewer Hose Recommendations? Neophyte Waste Systems, Tanks & Totes 4 09-05-2006 10:04 PM
Sewer hose mpumphrey04 Waste Systems, Tanks & Totes 2 11-30-2005 08:18 PM
Sewer hose recommendation TomW Waste Systems, Tanks & Totes 7 06-24-2005 09:23 PM
