Old 09-25-2006, 01:07 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Arrow Sewer hookup-what to get
The trailer came with one 10' hose and it has plenty of holes.
So assuming I'm starting with nothing, what should I get to be compatible at most sites and what about these flush systems.
'77 Sovereign Intl 31' CB
Old 09-25-2006, 01:15 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use my Sewer Solution about 99% of the time. For a quick dump at the campground dump station I gots the regular old SSSS...(Super Stinky Sewer Slinky)
Aaron
WBCCI #XXXX AIR #2495
Old 09-25-2006, 01:33 PM   #3
1992 34' Limited
Falls Church , Virginia
Black Tank st*nk.... Peew!
Bob -
When my trialer was new to me I did a lot of asking around here and several members recommended the Flush King. Checked the web site and bought one. Use it religiously!!!
FK is esentially a clear elbow with water hose hookup with a ball valve (I carry a extra green hose so NO mixups occur), and a valve that allows the BT to fill, then dump.
I will flush the BT several times (water is paid for at Full Hookups) and am always surprised at how much Yuck comes out of there. I try for at least 2 flushes, filling the BT to at least 1/2 so that I am sure I got it ALL out. Not getting it all out is where the PEEW comes from. The 'twice fill/flush' cycle takes maybe 5 minutes, depending on water pressure.
The clear elbow allows for SEEING if you got it all. Not the most pleasant thing, I'll grant you! But I would rather SEE that it is all getting out of the BT, than to have problems present because I didn't, couldn't or wouldn't see that it was flushed properly.
My unit actually has a BT sprayer that the PO added but it so far sits untried by me - I have a better solution. Your experience my vary....!
Axel
SilverToy
BTW - I have no interest in FK, in any way. Period.
SilverToy is offline   Reply With Quote
Old 09-25-2006, 01:41 PM   #4
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
You need to be mindfull of what you get. Most models of Airstreams came with a sewer tap that is a slightly different size from the "standard" size bayonet mounting. But once you get that connection, I have found the standard hoses fit it. I also found that two 10' hoses are best. A 10' is sometimes too short to reach to some sewer ports. Also, most camp grounds require you to use either a donut or an elbow at the end of sewer hose into the septic port. Another good item is a hose support to help provide down hill flow. You might consider an all in one kit plus the hose support if the bayonet mount works with your sewer connection. See below from Camping World for $45-$50.
Family of Disney Fanatics
WBCCI# 4821
Old 09-25-2006, 01:52 PM   #5
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Your trailer was originally built with Thetford sewer fittings. Unless a PO changed them out to Valterra, make sure you end up with compatible sewer fittings or appropriate adapters. Thetford and Valterra don't mix - they will leak; not a good thing.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 09-25-2006, 01:59 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
It all looks original Thetford, I just rebuilt the gate valves so I know!
Old 09-25-2006, 02:06 PM   #7
2006 30' Safari
Orlando , Florida
Then peegreen is correct, you will need adapters to use the kit in the photo. I don't know if my '06 came with Thetford or Valtera, but I bought an elbow kit and the hose that came with the trailer fits without leaks or clamps.
WBCCI# 4821
Old 09-25-2006, 02:19 PM   #8
peegreen's Avatar
Looking under the hood of some newer Airstreams, I've noticed that some are manufactured with Thetford while others are using Valterra. Don't know the reason for the differences (model), but beware that your fittings may not be compatible with a neighbors. I'm not really into sharing sewer hoses anyway unless we're really good friends or a fellow A/Smer, 'cause you know our %&*# don't stink.
WBCCI 24291
New England Unit
Old 09-25-2006, 07:25 PM   #9
2006 30' Safari
Orlando , Florida
How do you tell the difference? Is it just the diameter?
WBCCI# 4821
Old 09-25-2006, 07:35 PM   #10
1975 27' Overlander
High River , Alberta
All of the Thetford fittings I've seen are white. They're also slightly larger in diameter.
AlbertF is offline   Reply With Quote
Old 09-25-2006, 08:00 PM   #11
2006 30' Safari
Orlando , Florida
Mine are all black. Does that mean that standard fixtures will fit? My hose is definately tight on the black bayonet connector that came with the trailer and the grey elbow I bought at Camping world.
Also, does Thetford make for anyone other than Airstream?
WBCCI# 4821
Old 09-25-2006, 09:28 PM   #12
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
As a rule, current Safaris have Valterra; Classics have Thetford.
Other high-end units also use Thetford. There is no doubt that the Thetford product is of better quality than Valterra. They go on and off more easily and don't leak.
John W. Irwin
WBCCI #9632
Old 09-25-2006, 09:31 PM   #13
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Anyone try this http://www.sewersolution.com/basic.htm
Claims the SewerSolution System includes SewerSolution pump unit, a 10' length of Dump Hose and the Full Hookup Adapter Kit. Everything you need to get started! Additional 10' Hose Kits are available to extend the range of your SewerSolution.
The SewerSolution Jet Pump is molded from high strength clear Lexan polycarbonate plastic. The jet nozzle swivels to switch from the Dump to Flush mode. It looks like about $90.
Old 09-26-2006, 08:19 AM   #14
2006 30' Safari
Orlando , Florida
I won't debate quality issues, because I really don't know and would not be surprised that Airstream saved the higher quality product for the Classic line; they certainly did when it comes to windows, but that is another thread in itself. But my connection doesn't leak and I really can't imagine anything going on any easier. You just slip the bayonet connector over the sewer outlet and turn it a quarter turn and presto, its connected. The hose does seem to fit the standard items at Camping World and even one of the couplers I got at Wal Mart so I'm sure it is the Valterra. I'll look on it this week end when I pick it up from the dealer that is installing the additional awnings and see if there are any brand markings or I'll just ask.
WBCCI# 4821
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
Sewer Hose length? AirHog Waste Systems, Tanks & Totes 16 04-21-2004 01:39 PM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 08:49 AM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
