Old 12-31-2006, 06:48 PM   #57
sparky5's Avatar
2004 19' International CCD
Ridgefield , Connecticut
Similar subject, but slightly off....I'm looking into setting up my trailer at home for use by overnight guests and more pending...my son who will be returning home from college to live (indefinately) upon graduation in May. I have the electric and water hook up figured out but am looking for advice on the sewer end. No pun intended. we have a septic tank and it currently has a circular cement cover. I was wondering if anyone can suggest how/where I might gat my hands on a cover that has the sewer hook up for the hose from the trailer so I can just set it up to dump directly into the septic? Have any of you encountered this and if so how did you solve it? any adice would be GREATLY appreciated!
Robin
sparky5 is offline   Reply With Quote
Old 12-31-2006, 06:50 PM   #58
sparky5's Avatar
please pardon the typos, I can't find my glasses at the moment
Robin
Old 12-31-2006, 06:54 PM   #59
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Bob, I got the sewer solution but I have not tried it yet. I will try it at the get together. After reading these posts I hope it is compatible. Otherwise I guess I will be using my old leaky big hose. I thought you din't have any plumbing?
Phil Gobie is offline   Reply With Quote
Old 12-31-2006, 07:02 PM   #60
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Sounds like you have the solution all figured out youself. Cast a new cover - they are just concrete - with 4" PVC pipe through the new one and hook the sewer hose from the camper to it like you would at the campground. When done with that setup put a cap over it without glue or glue on a screw cap and just screw on a sewer cap. You may need to think of sewer gasses venting back into the camper for the long haul but if you shut the valves on the camper that should not be an issue. You have vents on the trailer now and that should take care of it anyway.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-31-2006, 07:18 PM   #61
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Since you are on septic, make sure you don't use any harsh chemical tank additives in the Airstream (such as formaldahyde-based black tank additives like Thetford) . It will destroy the biotic balance in your septic tank.
If you use a holding tank treatment make sure it's septic compatible
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 12-31-2006, 08:35 PM   #62
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Hey I have a thetford/Valtre adapter. My 06 Classic came with Valtera. aparently new setup for the classics.
If you are coming to the can opener it's yours... I have not seen it lately, may have been destroyed in the accident
Michelle TAC MT-0
Sarah, Snowball
Old 12-31-2006, 09:41 PM   #63
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
oooohhhhhh - I am coming down to your spot to help you look. Those things are like gold. Black Gold that is......
Old 12-31-2006, 10:13 PM   #64
_
clancy boy...
i was in a local rv shop last week...
very old school place...
they had a wall of thetford fittings...
bits from the tank opening,
all the way out to the hose,
and adapters galore...
if you need something, they've got it...
we can talk at the rally.
cheers
2air'
Old 12-31-2006, 10:32 PM   #65
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
From our own forum link under restoration parts: Out of Doors Mart
Online Store - outofdoorsmart.com
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
Sewer Hose length? AirHog Waste Systems, Tanks & Totes 16 04-21-2004 01:39 PM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 08:49 AM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
