11-14-2011, 10:03 PM
#21
2006 19' Safari SE
Tucson
We have a flush connection on our 2006 19' Safari SE LS...maybe is an "LS" thing...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
11-15-2011, 04:22 AM
#22
Mantua
, Ohio
It is a LS thing. jim
11-15-2011, 08:35 AM
#23
Contributing Member
Austin (Hays County)
I understand that a friend recently mistakenly hooked up the city water to his flush instead of to his city water inlet. Things overflowed badly, including some things recently put in the toilet.
Not a problem in mine since the flush inlet is much different and located well away from the city water inlet. In addition, I use a quick disconnect fitting on my city water and not on the flush, so I could not hook to the wrong place.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
11-15-2011, 08:47 AM
#24
Mantua
, Ohio
That is why it is so important to leave the valves open when using the flush. What a mess, but with it that full I bet it flushed out good. jim
11-15-2011, 08:54 AM
#25
2008 27' Classic FB
Burkburnett
Originally Posted by Pahaska
... I use a quick disconnect fitting on my city water and not on the flush, so I could not hook to the wrong place.
That's a great suggestion
AIR 47751
11-15-2011, 08:58 AM
#26
2009 27' FB International
Los Angeles
We haven't made this mistake yet, but I do wish there was more separation betwee the City Water connection and the sewar flush hookup. Additionally I wish the connection for the sewar flush wasn't directly above the city water inlet since it always drips. Even knowing there is an anti-siphon valve, it still makes me a nervous about contamination.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
11-15-2011, 08:59 AM
#27
2011 28' International
Chatham
, Ontario
I've not been able to make much use of my black tank flush as most of the camp grounds I've used this year have only had electricity to the site and I've needed to use the dump station after camping. I haven't yet found a dump station in Ontario that has a (working) water supply that I can connect to the black tank flush on my Airstream because what water is supplied has comes through a pipe with no hose connector fitted. My usual course of action is to dump the tank then put some clean water down the toilet when I get home, hoping that any solids left in the tank don't go hard in the meantime.
Camping in the US has been better where most dump stations have had a water supply with a hose connector or I've had a sewer and water point at the site.
Not quite on topic but I wanted to get that off my chest!
11-15-2011, 10:17 AM
#28
Port Orchard
Belt and suspenders
I use brass quick connects and white hose on drinking water, and plastic quick connects and green hose for SewerSolution and flushing fittings.
Ken
05-25-2018, 09:03 PM
#29
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Originally Posted by moosetags
My understanding of the built-in black tank sewer flusher in Lucy (our 2005 Safari) is that it consists of one or more pvc pipes (tubes) inside the black tank with numerous holes drilled in them. Fresh water is applied to these tubes from an external water inlet directly above the city water inlet on the left side of the trailer. The water from these holes rinses the black tank with clean water. It always gets out additional "crap" hiding in the black tank.
This system has worked well for us over the years. We use it every time that we dump Lucy's black tank. We also use this system after we close the black tank valve to put a couple of gallons of fresh water into the black tank to keep it wet.
Lucy has never been winterized, so I don't really know how to winterize the sewer flush. I would think that blowing compressed air through the tubes should do it.
Brian
Where did you have the tank tags made?
05-25-2018, 09:23 PM
#30
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Any small sign shop or trophy shop can make signs like this. They bare engraved signs in plastic. You can specify sign size and color. I used to be in the engraving business and made these signs myself.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
05-25-2018, 09:26 PM
#31
1999 34' Excella
Hillsboro
"Trophy shop" will make many different types of these 'labels'.. even metal ones..
Here is a promising one..
https://www.thesignchef.com/custom-l...ngraved-signs/
Peace and Blessings..
Channing
WBCCI# 30676
06-19-2018, 07:57 AM
#32
Manassas
, Virginia
My balck water tank washdown has never worked. Does anyone know where the vacuum breaker is located on a 2017 AS Classic?
06-19-2018, 08:19 AM
#33
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Right behind the water connection on the outside. 30’ is under the sink in the bathroom.
