Old 10-10-2012, 08:18 AM   #1
Loeber's Avatar
Calgary , Alberta
Sewer drain doesn't hook up
The trailer drain on my '79 International will not "hook up" with the sewer hose I have. The original one was beat up and leaked so I bought a new Rhino system for it and the coupling is 3/16" smaller in diameter than the valve coupling on my trailer. Of course I threw out the old coupling before I tried to drain my tanks. Is Airstream unique in its hose sizes or am I dealing with a rogue fitting installation? I (my wife) would really like me to drain the black tank ASAP. Any help or advise would be great.
Dan Loeb #7735
Loeber is offline   Reply With Quote
Old 10-10-2012, 08:22 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
There are two systems...and probably you have the older one. Check out Valtera as the newer one and when you fix the problem go that route. You can compare the systems on Vintage Trailer Supply or Camping World sites.
Old 10-10-2012, 09:15 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
This is what you might need: buy several as they break very easy.
Valterra T05-2285VP Thetford to Valterra Universal Adapter
Valterra T05-2285VP Thetford to Valterra Universal Adapter : Amazon.com : Automotive
MICHAEL
Old 10-10-2012, 10:28 AM   #4
1974 Argosy 20
Kooskia , Idaho
The original ones were Thetford. Not as easy to get these days as in the past but most RV places may have them or can order them for you. The adaptor mentioned in the other posts is another alternative.
Old 10-10-2012, 10:33 AM   #5
judflor's Avatar
1977 31' Sovereign
Stuart , Florida
Had same problem. We bought an adapter. The only problem is that it extends the connection point and it could be a problem if your original connection is "close" to the ground.
judflor is offline   Reply With Quote
Old 10-10-2012, 11:01 AM   #6
Loeber's Avatar
Calgary , Alberta
Thanks for the advise. 3 adaptors on order. I just need to be able to get my tanks empty before it freezes up here. (it is snowing as I write this) I can deal with changing valves and hoses once it is put away for the winter. I love this place.
Old 10-10-2012, 11:06 AM   #7
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Go out in the country....way out.... away from civilization....go to the valve handle....stand back and pull the handle. You don't need no stinkin' hose.
Old 10-10-2012, 11:32 AM   #8
Loeber's Avatar
Calgary , Alberta
Yeahhhhhhhhh about that.......
The grey tank might have been drained that way this weekend but the thought of doing the black tank the same way offended my good wife's sense of what is proper and nice.
Old 10-10-2012, 11:48 AM   #9
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Watch your shoes, too.
Old 10-10-2012, 11:51 AM   #10
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Try to get upwind. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 10-10-2012, 12:26 PM   #11
Gainesville , Florida
Could be a size able fine in some places also. Many dollars and some places make you clean it up. Jim
Old 10-10-2012, 12:56 PM   #12
AWCHIEF's Avatar
Images: 33
I also ordered a couple of more today. Had one break this past weekend at the worst time.
MICHAEL
Old 10-10-2012, 01:26 PM   #13
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
PUT ON GLOVES --- Go to a dump station - one with a pipe surrounded by sloping concrete. Park the dump valve over the concrete as close to the drain as possible. Tie some line on the handle - how long may be important here (20 feet was what I remember). Pull handle using line and let drain. Wash area with hose at station. Pull trailer forward THEN close drain valve. Leave.
I have never done this - I do not know where you got this information - I do not know your name....... Have a nice day.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
