Old 10-08-2015, 08:52 AM   #1
SDP 28 FC's Avatar
2016 28' Flying Cloud
Glen Rose , Texas
Question Sewer and Related
We are new to Airstreaming and this community and would really appreciate some advice and guidance in the category of sewer issues:
1. What type of holding tank neutralizer/deodorant works best? (Aqua-Kem, etc.?)
2. What is the best toilet bowl cleaner to use that won't damage the seals or the system?
Any other recommendations, suggestions, advice, or otherwise would be greatly appreciated.
SDP 28 FC is offline   Reply With Quote
Old 10-08-2015, 10:12 AM   #2
Missouri Valley , Iowa
A full-timer friend gave me this recipe. It works well for us and if odor persists we just add a bit more treatment. The mix : 1 part Liquid Wisk (I suspect any laundry soap will work); 1 part Pine-Sol; 1 part liquid Downy; 1/4 part lemon Ammonia. We pour, maybe, 1/2 cup of the mix in the bowl, add sufficient water to dilute and flush. You can also clean the toilet with this mix. The mixture will separate so shake the container before using.
Dan
Farmer Dan is offline   Reply With Quote
Old 10-09-2015, 09:40 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Aqua-Kem in the packets work well for ours. Valves and seals appear to function well.
Remember, plenty of water in the Black Tank.
Also, if you use the recipe FarmerDan shared, you could use in your sink traps.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-09-2015, 10:24 PM   #4
2014 23' Flying Cloud
Park City , Utah
OK, Flying Cloud Newbie here too. Spending the first night in mine in the seller's driveway, going through the systems. Reading this thread, I'm curious...what is the conversation regarding odor. Assuming there is a couple water in the bowl above the flush valve...why would there be an odor issue? Or does the issue arise in the moment of flush when the bowl is open to the tank below?
The things I find myself wondering about with my new toy
pcskier is offline   Reply With Quote
Old 10-09-2015, 10:32 PM   #5
2007 22' International CCD
Yup. It's the moment of flush. You then have a wide open valve leading directly to the black tank.
A little negative pressure inside the AS and there you go. Black tank odor prevention can be an issue. Remembering to shut off exhaust vents is another.....😥
KE4GNK/AE
Old 10-10-2015, 08:31 AM   #6
daboose's Avatar
2014 25' FB Flying Cloud
Matthews , North Carolina
Images: 11
We're using these 2 products; both are microbial probiotic technology.
Tank Maintainance
TanktechsRx
(Check out the Airforum TankTechRX thread)
Toilet Bowl Cleaner
Unique RV Toilet Bowl Cleaner & Tank Enhancer
ID:	250113   Click image for larger version
daboose is offline   Reply With Quote
Old 10-10-2015, 10:19 AM   #7
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I stopped putting any chemicals in our tanks without any problems. As long as I have a vent or window open when running any fans (like running range fan or shower fan) I have no odor issues.
Landrum is offline   Reply With Quote
Old 10-10-2015, 10:51 AM   #8
Retail6's Avatar
2007 28' Safari SE
Springdale , Arkansas
Landrum, I am glad you mentioned that. Thought there would be more of us that have opted out of that. Between cost and possible down stream impacts, I don't do it any more either.
Retail6 is offline   Reply With Quote
Old 10-10-2015, 07:20 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My AS has always been "used" and used chemicals. When I replaced the dump valves the tank had no "solids/cake" remaining.
Remember, plenty of water gives a good flush and will force the air into the tank.. So no "backdraft" of tank odor. Shutting off the bath fan will help restore "positive" air pressure in RV.
Channing
WBCCI# 30676
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
