Old 04-11-2011, 08:14 AM   #15
1994 25' Excella
Los Angeles , California
Yes, Bluto, there was the same insulation under the valves as under the tanks. I'll probably cut a piece to fit right in there when I put the access door back in place.
I'm trying to put a snug support around everything because over time, road vibration will cause looseness and cracks in the valves where they attach to the tank. Hope this helps.
godaddy64 is offline   Reply With Quote
Old 04-11-2011, 09:38 AM   #16
2010 27' FB Classic
N/A , Texas
Thanks, This was an enlighting thread for me.
Old 04-19-2011, 11:11 PM   #17
1994 25' Excella
Update: I've only had a couple of hours to work on the trailer since last time, but I was able to r/r both dump valves. Time will tell if it's a good job, but here's what I did:
I'm using the back half of the old valve, which is glued permanently to the 3" black sewage pipe. My understanding is that if you purchase a gasket kit for these Thetford valves, you won't get the little grommet that seals the plunger on the side. That's why I got whole replacement valve, dissassembled it, and migrated all the new parts onto the old back half/sewage pipe.
Be careful with the steel rod coming in/out of the little hole with a fresh grommet. It's a tight fit, so I worked it slowly. But once the plunger's done, the rest is just matching up the new half to the old one, and make sure the gasket lines up with no creases.
Out with the old, in with the new/old. The valve on the left is done, the one on the right is about to be put together.
Presto.
And if you could please tilt your head to the left, ladies and gentlemen...
All that's left is to install the mounting collars on the Black/Gray tank, and screw the valves/pipes onto them. I'm planning on using a 1/4" bead of plumber's putty around the collar as it slides into the tank. If you can think of a better way to seal it, by all means let me know. IMO this is the weakest link in all of the system as far as leak potential, so I want to get the assembly just *click, click of tongue* perfectly right.
And that will be the next photo installment. Hope this helps some other noob in need.
ID:	127683   Click image for larger version
ID:	127685   Click image for larger version
1994 excella, 25', sewage leak
Just got a '54 Cruiser- replacing floor tinman54 1950 - 1958 Cruiser 560 09-02-2016 05:52 AM
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 05:21 PM
removing center section of belly under axles robertel Belly Pans & Banana Wraps 10 04-21-2011 12:05 PM
Keeping water out. GeocamperAS Belly Pans & Banana Wraps 3 03-06-2011 08:32 AM
22' 1975 Argosy rear door CMSmith All Argosy Trailers 5 02-06-2011 08:36 PM
