Old 03-16-2012, 08:17 AM   #1
1967 28' Ambassador
West Point , Mississippi
sewage
So we just purchased our 1967 camper which has sat for 5 years with contents in the black tank. Last week I put a packet in the toilet with some water. Yesterday we hauled her to a nearby campground to dump the tank. After several tries of various directions nothing came out except the packet. After the stick and flashlight test it has solidified in the tank! How in the world do we get this crap (literally LOL) out of there?
KECM is offline   Reply With Quote
Old 03-16-2012, 08:34 AM   #2
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Couple of gallons of water and some degreaser.....5-10 miles on abumpy road?
Greg
Greg@AirLA is offline   Reply With Quote
Old 03-16-2012, 08:35 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
I wouldn't worry too much. With use the accumulated solids will mostly dissolve. You can speed things up with various chemicals but they will also attack the seals in the dump valve.
Old 03-16-2012, 08:43 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
What you are referring to is known as the "black hills syndrome". This is what happens when a black tank is allowed to go completely dry. This is something that should never be allowed to happen.
There are several things that you can try to counter this situation. Put some RV toilet chemical and a half tank of water and let it sit overnight. Add a couple of bags of ice through the toilet. Immediately take the trailer for a rough ride with sudden stops and quick take offs. Also throw in a rough road to let the ice do some work on the black hills. You may need to repeat this several times to get any results.
In the more severe cases, the black tank may need to be replaced.
Brian
SuEllyn & Brian McCabe
Old 03-16-2012, 08:44 AM   #5
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
A bag of ice cubes and ride around for a while. Sal. PS I wonder if milk of magnesia would help.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-16-2012, 08:53 AM   #6
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
That's going on my list of useful things to have in my trailer
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 03-16-2012, 10:45 AM   #7
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
You could try to putting a water hose with pressure nozzle
in the toilet opening, which hopefully will shake things up!!
william Haym is offline   Reply With Quote
Old 03-16-2012, 11:09 AM   #8
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Who can resist a thread titled "Sewage"?
All good ideas so far (except, maybe, milk of magnesia) and I have nothing to add.
Gene
Old 03-16-2012, 11:25 AM   #9
noreen&sal's Avatar
1981 27' Excella II
Gene
Maybe ExLax? Sal.
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
Old 03-16-2012, 11:53 AM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
"Chemicals" - nothing lye based PLEASE. Use something that is enzyme based. This literally helps digest and soften the stuff rather than just burning it (and the seals and the tank). Also a lot of the older chemicals had a lot of formaldehyde in them. This was part of the odor control, but it inhibited bacterial and enzymatic action. The old chemicals have long lost their potency, but may have created an almost waxy "texture" to the remaining crap.
The bumpy road and ice cube trick can work quite well if your tank is say 70% clear and 30% mountain. If it's 70% full of sh** then time and warmth are your allies. Plow in a big load of something designed to be safe for a septic tank (bio-active) that will encourage fermentation - and fill the tank with WARM not hot water. Every 3 - 4 hours rock the RV back and forth using the trailer's jack (stabilizers up). Before trying to dump, gently agitate one more time, then open the valvve. If what comes out looks like baby diarrhea - you're making progress. Repeat. If what comes out looks like it's just weak tea, you have three options:
  1. new black tank, someone with a sick sense of humor might have dumped portland cement down the drain
  2. call a septic tank pumping service and see if they can do this kind of work
  3. get a pressure wand - and go to work from the top down with hot water and a LOT of persistance
Also at the risk of stating the obvious - make sure your black tank isn't actually empty! The 60's tanks were SMALL - and when you look down the throat of the toilet and see black, its possible tank might BE black plastic. Fill your tank with a big drywall bucket or cat food bucket that holds 5 gallons. If you can get two bucketfulls into the black tank, that might be it's total capacity. Check the specs for your year and model.
Good luck!
Old 03-16-2012, 02:21 PM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
If it's bad enough you can dissolve it with chlorine. It will wreck the dump valve seals, and the toilet valve if you get any on it, but shouldn't affect the tank or the piping. You have to be sure there's plenty of ventilation and that the tank vent isn't plugged since there will be fumes. Wear goggle, gloves, and a face shield.
Old 03-16-2012, 02:21 PM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Our tank is always emptied between travels. I can do it at home if I didn't make or have the opportunity at the last campground. HOWEVER, upon the next excursion, sooner or later, I dump a bag of ice cubes in and by the time we reach our first destination the tank has had a good scouring.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-16-2012, 02:33 PM   #13
Ottawa , ON
Still laughing over that comment, Gene!!
Old 03-19-2012, 06:31 AM   #14
1967 28' Ambassador
With lots of persistance this weekend, we finally got the tank to drain! Thank you all for your help! Now on to the plumbing issues
What to do when there is no sewage hookup? Eaglemate Airstream Lifestyle 38 12-27-2011 06:29 AM
sewage system cwlandyacht Forum Rallies & Meet Ups 0 09-01-2011 06:33 AM
Sewage in Belly - EW! godaddy64 Waste Systems, Tanks & Totes 16 04-19-2011 11:11 PM
Rally Sewage Goes Where ?? Distantdrummer Other Rallies & Events 10 02-17-2009 09:57 AM
Outside Sewage Smell timmy67 Waste Systems, Tanks & Totes 9 08-05-2008 12:57 PM
