Old 08-10-2011, 06:22 PM   #1
khadley's Avatar
1974 27' Overlander
full time in canada/US , British Columbia
Septic system ideas
Hi, we are moving our airstream onto some land, where we have water, electricity but at the moment not septic. The trailer is going to be hard to get in, so trundling off to dump, not an option. We can trickle the grey out, the surrounding fruit trees and gardens will appreciate that!
Issue is what to do with the other waste. There is a septic system for the house, which i think is up a hill... close to where we are the weeping field (think that's how it goes).
Does anyone have any good articles, or clever ideas on how we can rig things up to be able to live on that land septic-ly speaking!
kim & deb
(max/murphy)
www.airstreamdreaming.com
khadley is offline   Reply With Quote
Old 08-10-2011, 06:29 PM   #2
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
You could get a macerator pump and it would pump the chopped output from your black tank uphill to your septic tank through a small hose...
Thought this was a good article - http://www.modmyrv.com/2008/12/31/rv-macerator-pump
Darkspeed is offline   Reply With Quote
Old 08-10-2011, 07:06 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
If the trailer is on a permanent site one could always install a dedicated septic and drain field. If it's summer use only another possibility is a sealed pit and a sewage lift pump. They look like a sump pump, but they will pump sewage with no problems. I have two mounted in apartment stairwells. They pump twigs, candy wrappers, anything that fits into the inlet.
They have an outlet to fit 2" plastic pipe. They use a float switch like a sump pump. They're used a lot around here in sealed pits, for homes where the sceptics are in berms. Quite common.
Old 08-10-2011, 07:11 PM   #4
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
natures head! (Composting Toilet)Nature's Head Composting Toilets - The environmentally sustainable waterless toilet for Your Boat, RV, Cabin, Big Rig, Barn, Workshop, or Yurt!
ddstech is offline   Reply With Quote
Old 08-10-2011, 09:42 PM   #5
khadley's Avatar
1974 27' Overlander
RV chemicals in household septic
I like the macerator pump idea but I am concerned about putting the RV chemicals in the regular household septic. Might this be a problem?
kim & deb
(max/murphy)
Old 08-10-2011, 10:10 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There are several additives that are safe to use in your septic system.
Richard
Old 08-11-2011, 05:20 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
If you have the pump, why even spend the money on the blue stuff? Just don't put chemical in the tank, and empty every few days.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-11-2011, 05:42 AM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
You didn't say what the distance is between house and site. Macerator pump with a bit of water should work. Problem with the "Sewer Solutions" product is that it depends on water for maceration and carrying the waste away, using too much water for daily use and wouldn't do a good job if too long a distance and too big a hill.
Old 08-11-2011, 08:20 AM   #9
khadley's Avatar
1974 27' Overlander
wow, thanks all for the helpful advice. I'll have to measure the distance, pretty sure it's at lest 50 ft or more. I don't find the blue stuff works well, so typically don't put anything in the tank, but i have heard if you are going to dump into houshold septic, not to use it.
kim & deb
(max/murphy)
Old 04-11-2012, 09:49 AM   #10
1972 31' Sovereign
rodanthe , North Carolina
What brand/model? I'm looking at macerator pumps but this sounds like something different?
fridder13 is offline   Reply With Quote
Old 04-11-2012, 10:14 AM   #11
khadley's Avatar
1974 27' Overlander
After spending a few months on the land, and hoofing it up to the washroom in the house as we contemplated the options, we've decided on the composting toilet. By all accounts the Natures Head is the best. I contacted two people who are living full time in rv's and use them so i feel that's the best reference! thanks for all the advice all.
kim & deb
(max/murphy)
Old 04-11-2012, 12:50 PM   #12
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
We have a septic tank but no way to dump into it without digging out the lid and removing it. Does anyone have any ideas how to put a a fitting into the tank so I can dump? I suppose I'll have to drill into the concrete case and install a fitting. Any ideas??
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 04-11-2012, 01:04 PM   #13
Splitrock's Avatar
Any concrete cutter with a core drill can drill the hole in the top. Then just install a 6" PVC stack with a removable cap and you're all set. My cutter has a gas powered core drill. Slab jackers have core drilling equipment too.
Old 04-11-2012, 01:28 PM   #14
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Most tanks have multiple openings high on the side that a 4 inch pipe can go in.. You could also T into the line from the house with a riser to dump in.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Black water flush system mjayjensen Waste Systems, Tanks & Totes 4 07-10-2011 05:21 PM
See-Level system installed crispyboy Waste Systems, Tanks & Totes 9 07-05-2011 05:45 PM
Suggestions for Home Theater System in Airstream FLMarine Audio, Video & TV 4 06-23-2011 08:10 PM
Use of hitch system.. KyMoonshine Hitches, Couplers & Balls 14 04-11-2011 10:00 PM
Dual system? Am I going to blow it up? robwok Batteries, Univolts, Converters & Inverters 0 03-24-2011 07:45 AM
