Old 09-22-2004, 08:06 PM   #1
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Question Septic system hookup
I'm going to connect my Excella to a septic system in a semi-permanent setting. I figure I'll come out of the drain valve with a 90 degree bayonet adapter and convert from 3" to 4" with a flexible rubber converter (with hose clamps), and then connect to the 4" sewer pipe (which will run 12' or so under the trailer). Any suggestions out there? How about a line on a good parts source? Thanks, Roy
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 09-22-2004, 10:37 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
A home improvement store maybe.
Old 10-02-2004, 08:35 PM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
most mobile homes only run a 3" waste line. You can find all the fittings you need a the local home supply. Use 1/2 bubble on your level to get a good drain flow on your lines.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 09-04-2006, 07:48 PM   #4
San Antonio , Texas
How did the installation go? I'm thinking of doing the same thing and would love some "notes from the install"..
Gambit242 is offline   Reply With Quote
Fire Response System Over59 General Interior Topics 4 07-31-2004 10:23 PM
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 11:04 AM
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 3 09-26-2003 06:31 PM
How to add a b/tank flush system inthwind Waste Systems, Tanks & Totes 2 06-25-2003 09:59 AM
