Old 03-31-2015, 05:35 PM   #1
Grants Pass , 97527
septic connection
I was recently on the vintage trailer supply website, trying to figure out what connectors i need for my 62 airstream overlander 26' trailer. Turns out i need a bunch of parts to get things to fit from vintage to modern septic conneters. Before I get started i need to take a section of the belly pan panels off so i can see what needs to be done. How do i take apart the rivets and not damage them so I can reuse them when it comes time to put them back into place. What have I got myself into just need some much needed advice thanks.
Jesse Gus is offline   Reply With Quote
Old 03-31-2015, 07:26 PM   #2
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
You cannot reuse the rivets. You must drill them out and replace with new rivets when reinstalling the belly pan.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 03-31-2015, 10:27 PM   #3
Grants Pass , 97527
Are the tub and sink drain pipes going around the fiberglass waste tank or are they going into the waste tank, just was wondering.
Old 03-31-2015, 10:49 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Welcome aboard!
Do you have experience with 'pop rivets'? Here is a quick review:
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-31-2015, 10:51 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh.. found this... I did NOT download it... but, there is hope to find what you need..
Download 1971 Airstream Service Manual | Tricia Joy
Here is another site:
http://www.airstreamofficialmanuals.com/about.html
Channing
WBCCI# 30676
Old 04-01-2015, 06:35 AM   #6
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
If your trailer has the original sewer connections installed, all it should take is a simple adapter to connect newer sewer line hose to your trailer. Before you take anything apart, investigate a Thetford to Valterra adapter.
Older trailer like yours and mine don't have a gray tank. The drain lines from the sink and the shower connect downstream of the dump valve. Back in the day, no one cared what you did with gray water. Now we have to use a portable tank or add a gray tank to the trailer.
Good luck.
Old 04-01-2015, 10:44 AM   #7
Grants Pass , 97527
What size drill bit do i need to drill out the old rivets, so I don't make the hole bigger. Also should i use aluminum rivets so it won't rust or steel.Once i put it all back together. Thanks
Old 04-01-2015, 02:36 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Get Olympic rivets from vintagetrailersupply.com or Out Of Doors Mart. Regular home center ones will leak water
For repair work a 1/8" drill and 5/32" rivet will work. There are specialized tools that are worth having if you are working on a large area.
Old 04-01-2015, 04:14 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If doing a few panels, getting a pneumatic pop-river gun is good idea
Channing
WBCCI# 30676
Plumb black water tank to septic system? '72Tradewind Waste Systems, Tanks & Totes 5 09-10-2006 09:32 PM
Septic system hookup rfield54 Waste Systems, Tanks & Totes 3 09-04-2006 07:48 PM
The effect of using the blue liquid black water treatment on septic fields wacnstac Waste Systems, Tanks & Totes 6 06-01-2006 09:21 PM
67 Globetrotter septic identification nu2argosy Waste Systems, Tanks & Totes 2 04-01-2006 11:35 AM
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 3 09-26-2003 06:31 PM
