Old 07-13-2011, 05:14 PM   #1
Tennille , Georgia
Septic backing up into shower
The stuff is starting to get deep!I've been trying to drain the auxiliary tank, but nothing was coming out. Today, the shower was full to the top with black water. Opening the main tank, the shower drained. But now it refuses to go down any further, and it does smell... and I need a shower... Help? Plunging hasn't cut it.
Capt Quirk is offline   Reply With Quote
Old 07-13-2011, 05:22 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
What year/model trailer are you dealing with here?
Shari
Old 07-13-2011, 05:46 PM   #3
Tennille , Georgia
Duh... Yeah, that would help. It's a 77 Airstream 32'(?) Landyacht.
Old 07-13-2011, 06:11 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think your trailer has 2 dump valves. One for the grey tank and one for the black tank. Are you saying that when you open the black tank valve it backs into the shower? Does either tanks contents empty thru the hose connection?
TG Twinkie is online now   Reply With Quote
Old 07-13-2011, 06:17 PM   #5
Tennille , Georgia
I open the grey water valve, nothing comes out. The shower filled up with black water, and would not drain until I opened the black water tank.
Old 07-13-2011, 06:40 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Next question: Do you know if it's ever worked correctly?
Old 07-13-2011, 06:55 PM   #7
Tennille , Georgia
It did, more or less, until recently. Then I couldn't get anything out of the grey water tank.
Old 07-13-2011, 06:56 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
My owner's manual says to empty tanks, put on drain hose, open valves, when tanks are empty close valves.
I wonder if a valve is broken. . .
Old 07-13-2011, 07:09 PM   #9
Tennille , Georgia
I hope not. I don't even want to think about fixing that.
Old 07-13-2011, 07:15 PM   #10
Splitrock's Avatar
I'd much rather fix a valve than have a shower full of black water. Just saying . . .
Old 07-13-2011, 07:20 PM   #11
Tennille , Georgia
I'll just keep the blackwater open, and shower outside... it is still summer
Old 07-13-2011, 07:32 PM   #12
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Open the gray water dump and turn on some faucets. Does water come out the dump port? Are you sure you don't have the valves mixed up? It seems that on my early 80s unit had the black tank was labeled main, and the gray as aux.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-13-2011, 07:41 PM   #13
Tennille , Georgia
The tanks are labled the same as when I got the trailer. I'll try turning on some faucets tomorrow, when there is light.
Old 07-13-2011, 07:43 PM   #14
x
XXXX , XXXX
If you keep the black tank valve open the liquids will drain away and you'll end up with a poop pyramid at the bottom of the tank right below the toilet.
wasagachris is offline   Reply With Quote
Do you use your shower? Scott J-24 Sinks, Showers & Toilets 117 01-16-2012 04:43 PM
Replacing Shower Door jmichaelr General Interior Topics 3 07-21-2011 03:47 PM
Towel bar in shower fell off Bigcgar General Interior Topics 11 06-04-2011 04:35 AM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
