Old 05-03-2014, 04:03 PM   #15
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Aviator,
I got my tanks from Inca Plastics. They did great for me. They have molded RV tanks for years, and have lots of old molds for low volume service parts. I just went through their on line catalog until I found a tank that fit my frame bay. See "Inca Plastics Did Great" thread in this forum for more information. I also have a tread called "mounting waste tanks" in this forum with a couple more pictures.
The tanks I ordered came with mounting ledges molded in. I "hung" the tanks with angle irons from the frame rails. I think they are very secure under there. I also had fabricated a tank and valve cover that I will bolt to the frame and stringers to protect the tanks. I'll insulate it and have provided a heat duct from my furnace (as well as a cold air return duct.)
Hope this answers your question...
David
Old 05-03-2014, 06:33 PM   #16
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 07-13-2015, 09:18 PM   #17
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
Originally Posted by Mixter View Post
What's minium tank depth on those sensor strips? My black tank looks to have plenty of room, but the gray looks to be only 3"+... not much anyway.
Also, is there any concern with the strips coming un-stuck?
Minimum cut size is 4.5", with cuts every 1.5" to the full length of the monitor (9" I think). There is a procedure to use up to 2 strips if you had an unusually deep tank. They recommend cleaning the tanks with acetone before attaching, once stuck that's where they are going to stay unless you want to replace them... you will destroy the sensors to remove them.
It is very well designed and the included directions are clear and pretty fool proof. They want an inch of clearance to any metal from the sensors surface... off of the edge does not really matter. Haven't finished sticking mine on yet... they are just temporarily on with painters tape to make sure they are properly placed to get full and empty readings. My water tank is under gaucho and easy to access... the twin rears are of my own design and finding a spot to put them was on them not difficult. I had to cut a little metal from the sheet metal box I put them in to mount them but otherwise simple to install. I did the full Monty to our 68 Tradewind and expect it to be ready to maiden next month. I got the SeeLevel II unit in my XMAS stocking... and just put it in a couple of weeks ago. Empty tests well on all tanks... I have to get around to testing full and in between. Just finalized all of the plumbing installs last weekend so its not far off. The black and grey tanks had been filled and drained to test them even before I put the system in. 12V and 115V are almost done as well, gas lines are fit and "hung" with zip ties to pressure test before pan goes back in. Solar is in and charging the batteries. Getting anxious to take it down the road but want to do it only once and right.
Chuck
cwbiii is offline   Reply With Quote
Tank side wall height for SeeLevel Sensors? mtntime Plumbing - Systems & Fixtures 1 06-15-2012 10:26 AM
Tank monitors, level sensors and/or gauges. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 16 09-24-2010 12:09 PM
SeeLevel II display not working johnandlauri General Repair Forum 0 09-17-2010 08:09 AM
Seelevel Monitoring Systems rickandsandi Waste Systems, Tanks & Totes 3 10-13-2009 07:48 AM
SeeLevel Gauges 68 Overlander Commercial Listings 11 07-11-2007 11:12 AM
