| Seelevel Monitoring Systems
OK.... I have given up on the AS supplied monitoring system as I know so many of you have also. AS had replaced the unit and recalibrated it and it seemed to work for a while. Of cours the battery monitor section of the unit is a joke and is being replaced with a Tritronics, but we never have fresh water even when we fill the tank and the grey and black give different reading as they see fit. I have done some research on the Seelevel System and so far I really like what I see. Of course installing the system will be a major undertaking but if it works it will be well worth the effort. We spend a lot of time boondocking or limited hook-ups so an accurate system would be very helpful. Has anyone installed this unit and anything special I should be aware of other than needing to gain access to the actual three tanks?
__________________ J. Rick Cipot Sandi Gould NEU New England Unit Airstream Life Magazine WBCCI #3411 AIR #17099 2009 Silverado 2500HD 2004 22' Safari 1960 24' Tradewind |
