Old 07-02-2014, 08:21 AM   #1
dznf0g's Avatar
Oswego , Illinois
See Level tank monitors
So, I searched for a good documentation thread relative to a See Level conversion on a late model Classic (or similar tank layout) 30'er. I didn't find one, unless it is lurking under some odd title. Anyone know of one?
I am specifically looking for info on:
Which model to use for Fresh, black, gray, 2 propane levels, battery level and has switch for water pump. IOW, a direct replacement of the Micropulse.
Which length sensors need to be used for the 37 gal gray, 37 gal black and 59 gal fresh?
Where are the current sensors located on the Classic?
How specifically did you gain access to the sensor locations?
-Rich-
SeeLevel Tank Monitors Okay? dbj216 Waste Systems, Tanks & Totes 16 07-13-2015 09:18 PM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
See-Level system installed crispyboy Waste Systems, Tanks & Totes 9 07-05-2011 05:45 PM
Tank monitors, level sensors and/or gauges. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 16 09-24-2010 12:09 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
