Old 04-14-2014, 02:56 PM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Seal Vent Pipe through Floor
What do I use to seal the gap between the vent pipe and the floor of my 1961 Bambi. The gap is small, but it needs a seal of some type so I don't have "things" crawl up through the inside of the belly pan.
thinktankair is offline   Reply With Quote
Old 04-15-2014, 01:47 AM   #2
1961 16' Bambi
Any ideas on this one?
Old 04-15-2014, 06:18 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Vulkum (Trempro 635) is a great all purpose sealant. Stick to just about anything and remains flexible. You can buy it from Vintage Trailer Supply, Out of Doors mart, or Inland RV. Some folks have had luck finding in the big lumber stores (Home Depot, Menards, etc.).
Old 04-15-2014, 06:36 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I use the expanding foam sealers like Great Stuff around pipes. Since you won't likely use the whole can you can clean the dispensing "hose" with lacquer thinner. The spray cans of Walmart carb cleaner appear to be just lacquer thinner and are good for clean up.
Excess foam can be cut away after it sets up
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-15-2014, 08:04 AM   #5
1961 16' Bambi
Thank you Rick and Munno!
Vent pipe seal thinktankair Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 02-27-2014 08:46 AM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
