Old 03-30-2015, 02:55 PM   #1
2000 30' Excella
Monticello , Florida
Seal advice for toilet
I am referbing my AS and now reinstalling my Theyford toilet the seals look good but do I need to lube them or do any thing before tightening it back in place? The toilet is a straight drop and not at all complex
07007 is offline   Reply With Quote
Old 03-30-2015, 04:00 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I'm not sure which seal you are referring to as there are two. One is at the base between the toilet and the floor. This seal is almost never a problem and can be used again as long as it is intact, still flexible, and makes full contact around the perimeter. The second seal is in the bottom of the bowl (blade seal). Leave it closed, place about a cup of water in the bowl, and see if it leaks (watch it for a few minutes). If the bowl holds water, you are good to go. If not, replace the blade seal before re-mounting the toilet.
SeeMore is offline   Reply With Quote
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
