Old 01-08-2004, 09:28 AM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
The nuke reactor requires tow vehicle speeds of 186,001 miles/second -- or else the shielding exceeds the GCWR of the tow vehicle. Gamma rays will rid you of tailgaters too (at c?)
5 meter Langford Nahanni
Old 01-08-2004, 09:42 AM   #16
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Just to make sure
The correct URL for purchasing Odor-Con is
www.billydump.com/3r/3rhome.htm
The last post noted that somehow I had got a period included at the end, but I noted that the URL in that post was the previous one that was actually incorrect due to the missing "y" in billy.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 01-08-2004, 10:48 AM   #17
Images: 59
Wind turbine
Darin:
here's your wind turbine-Air(stream)power
Old 01-08-2004, 12:37 PM   #18
Thanks Mark,
That site is great, and I was only half kidding about wind power, but there it is. Also filters for every use, led lights, solar systems, composting toilets, well worth checking out. I am amazed how with every question and problem there is an answer. I can see now there might be too many choices, and I am going to be spending much time researching the best options.
Darin
darin is offline   Reply With Quote
Old 01-08-2004, 12:53 PM   #19
Images: 59
A world of opportunity
Darin:
You've seen those ads on TV for "Invention Submission Corporation"?
That site is where all those inventions end up. Composting wind turbine reverse osmosis nuclear powered pond scum eliminators
Old 01-08-2004, 11:37 PM   #20
Thermasan
David sent me scrambling for the packet that came with my 'experienced' trailer. The previous owner must have had an interest because this was the only non-installed hardware brochure in the large envelope. The brochure cover advertises, "Turn the switch ... and join the unhooked generation."
A special "Aqua Aire" product was recommended "to control the exhaust emission." This might compete with catalytic convertors for advertising your passage? David, any observations on that?
4 scans are enclosed and reproduce the page that describes it best:
Old 01-08-2004, 11:38 PM   #21
2
Old 01-08-2004, 11:39 PM   #22
3
Old 01-08-2004, 11:43 PM   #23
4
Old 01-09-2004, 08:53 AM   #24
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Chemicals for ThermaSan
Interesting that you found some of the original advertising info. I remember as a kid that the ThermaSan was HIGH on the list of RV owners wants, but it's cost was the main deterrent to installation. I found the same flyer that you have and an additional one in the owner documentation from the units I purchased on eBay.
Yes, Thetford did recommend that you use Aqua-Air with the ThermaSan, but I suspect Thetford was looking for a continuing revenue stream (it is razor blades that make money, not the razors). While we have had a few good laughs about "don't follow us, we are burning "s&*t", the system does a complete job of destroying odors. There have been a few occasions while the ThermaSan was running that we stopped momentarily to check things and never once have we detected any odors or discharge. The system shuts down when the engine load drops or the speed falls below 35-40MPH. This ensures that there is adequate heat and gas flow to do the job before injecting effluence into the exhaust system. As for the Odor-Con (Chlorine Dioxide) being burned in the process, I am not all that worried as I only use an 1/2 oz per holding tank, and even if you break that down, you are only releasing oxygen and a small amount of chlorine (far less than evaporates off the top of a swimming pool).
BTW, understand that the fine mesh stainless screen in the intake probe on the black tank prevents solid matter from entering the system (only liquid and very small matter), so you still have to empty the tank the old fashioned way periodically (in our use, the ThermaSan is only used occasionally when dumping facilities are not available). We also have the A/S factory blacktank flush which I use to totally flush all matter out of the tank each time I empty the tank.
I have to admit, I installed the ThermaSan more from a nostalgic perspective and the novelty, but it does work and work well.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
