Old 12-02-2011, 07:25 AM   #41
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
When the sink traps at my mother's house got slow or foul, she would pour a teakettle of boiling water down them.
doug k
Old 12-02-2011, 07:43 AM   #42
1981 31' Excella II
New Market , Alabama
I have seen melted sink traps from pouring hot liquids down the sink.
Perry
Old 12-02-2011, 09:07 AM   #43
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Lightbulb Another thought...
I haven't seen mention of the floorcovering material in this trailer. If you (or PO) had a bad seal or leak and fixed it, could the carpet/vinyl/wood have been "wet" before? This could explain it.
Also, if the leak still remains, adding water will "re-constitute" the problem whether it is in the floorcovering, sub-floor or insulation around the tank...
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-02-2011, 09:21 AM   #44
dkottum's Avatar
perry' we have poured boiling water from cooking down our sinks for years at home and I figured it helped keeping the traps clean.
Are the melted traps you have seen pvc or some other kind of plastic? What plastic is in the Airstreams? What about the hot water supply lines?
doug k
Old 12-02-2011, 09:43 AM   #45
1981 31' Excella II
I think the Airstreams are ABS but that may change by year. Put some boiling water in the trap and see if you can squeeze it with your fingers. Standard PVC gets soft when heated to 212F. CPVC cross linked PVC does not. ABS melts just above the boiling point of water so it will get soft as well. I don't think traps are designed for long term boiling water exposure. Most hot water is around 120F and that is usually mixed with cold water. Boiling water 212F is a different story and that is close to or above the point when most thermoplastics like PVC or ABS are going to get soft.
Now if you are using brass traps you should not have to worry.
Hot water supply lines are usually made of crosslinked PCV or crosslinked polyethylene which makes them stronger and more resistant to high temperatures.
Perry
Old 12-02-2011, 12:18 PM   #46
Air-Texas's Avatar
2004 34' Classic S/O
Stafford , Virginia
Originally Posted by ROBERT CROSS View Post
Bye you'r leave Sir...
Friday Field Day...yes sir. Every Spring and Fall.
RLC.
I'll be in the area all day, hold the salutes....
Air-Texas is offline   Reply With Quote
Old 12-03-2011, 07:20 AM   #47
Air-Texas's Avatar
Stafford , Virginia
Field days were on Thursdays!
Old 12-03-2011, 05:54 PM   #48
Air-Texas's Avatar
Stafford , Virginia
Originally Posted by Goal15
this is a long shot but I recently pulled, toilet to replace valve and inside underside of toilet was disgusting I didn't stick my nose in it to see if it smelled but out could be your culprit
It was the seal, I removed the toilet, and the donut seal was almost gone....
But, on the bright side, after all that bleach in the tank, there was NO smell, or should I say, only the smell of bleach....
I also poured some olive oil into both tanks, and it did make opening and closing the valves easier!
Black water tank removal 1975 Mus289 Waste Systems, Tanks & Totes 7 04-17-2017 08:27 AM
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
Black and Gray water holding tank leak GoodRed Road 1974 - 1979 Ambassador 0 09-19-2011 04:39 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 10:15 PM
