Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 03-30-2017, 01:48 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
?s on outfitting outlet/inlet/vent fixtures on gray tank...
I am having a custom aluminum gray tank made for my Bambi II. It will have approximately a 16 gallon capacity. The frame rails are small on a Bambi (3.5") and we are making it to fit so it only protrudes slightly below the rails. A few questions...
1) Do I need to have a separate inlet for the sink and shower, or can they share an inlet that is ALSO the outlet? (How many fittings do I really need to put on this tank?)
2) Can the inlets be low on the tank? I don't have much choice because of space restraints.
Bottom line, can I have the sink and shower drain connected to one inlet fitting that also acts as the outlet? With that configuration, I would only need to fit one outlet/inlet and a vent out the top.
Any help appreciated! I an getting ready to get the tank into production soon. Excited the flexibility a gray tank will afford us this summer!
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Furrion Stainless Steel 30A inlet and TV inlet Gsmblue Electrical - Systems, Generators, Batteries & Solar 4 07-27-2015 06:58 PM
Buying and outfitting a 25FB M and M Towing, Tow Vehicles & Hitches 24 07-22-2015 04:09 PM
really excited outfitting Airstream as Food Vendor unit AirConditioner Working on the Road 5 08-28-2011 09:05 PM
Outfitting AS for FTing fr8tshaker Full-Timing 31 06-17-2010 08:47 PM
