Old 02-19-2015, 12:03 PM   #1
1982 27' Excella
Huntsville , Texas
Rust at rear by dump valves
I recently purchase a 27' 1982 excella. The dump valves were not shutting off completely so I removed the rear bumper hoping I could get access to the shut off valves. What I found was a lot of rust on the frame and what was apparently a metal sheet between the rear plastic tray and the holding tanks. Any suggestions on how to replace the rusted metal sheet and repair the other damage would be greatly appreciated.
Name:	Dump Valve 1.jpg
ID:	232723   Click image for larger version
Name:	Dump Valve 2.jpg
Name:	Dump Valve 3.jpg
ID:	232725   Click image for larger version
Name:	Dump Valve 4.jpg
GMarugg is offline   Reply With Quote
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Holding Tank Dump Valves odfarley 1966-68 Caravel 2 08-06-2003 10:38 AM
Knocked off dump valves! Astrodokk Airstream Motorhome Forums 7 07-13-2003 09:32 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
