Originally Posted by vhord
I received my replacement black tank from Inca Plastics today. Since I was not exactly sure of the positioning of the inlets I did not have them install the welded in fittings. Instead they furnished me with rubber grommet inlet adapters that just pop into a drilled hole. They said to seal them with a butyl caulk.
There will be one 3" inlet for the toilet and one 1-1/2" inlet for the vent. Is there anything wrong with using these or should I find someone to plastic weld in the inlet fittings?
Attachment 56579
When the trailer bounces around, in time, you will find out that the grommets leak.
Of course you will only find that out on a trip, where you can't do anything about the leaks, until you get back home.
We refuse to use them.
