Old 03-20-2008, 11:00 AM   #1
vhord's Avatar
Images: 96
Rubber grommet inlets for black tank?
I received my replacement black tank from Inca Plastics today. Since I was not exactly sure of the positioning of the inlets I did not have them install the welded in fittings. Instead they furnished me with rubber grommet inlet adapters that just pop into a drilled hole. They said to seal them with a butyl caulk.
There will be one 3" inlet for the toilet and one 1-1/2" inlet for the vent. Is there anything wrong with using these or should I find someone to plastic weld in the inlet fittings?
vhord is offline   Reply With Quote
Old 03-20-2008, 12:06 PM   #2
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
I'm using those too.
As long as they are in the top of the tank they should be just fine. the only time you might have a problem is if you overflow the tank and leave it in overflow for a long time... I don't plan on doing that.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-20-2008, 12:29 PM   #3
Attachment 56579
When the trailer bounces around, in time, you will find out that the grommets leak.
Of course you will only find that out on a trip, where you can't do anything about the leaks, until you get back home.
We refuse to use them.
Old 03-20-2008, 01:02 PM   #4
1967 28' Ambassador
1970 29' Ambassador
For the same reason... the spin welded/cast-in fittings can crack. Six of one/half a dozen of another... I prefer the flexibility of the rubber grommets for vents and inlets.
Steve & the crew
Do I have to use the Black Tank? jimsease Waste Systems, Tanks & Totes 8 08-09-2006 10:22 PM
Black Tank Devoman Waste Systems, Tanks & Totes 14 08-02-2006 12:13 PM
Black rubber T-handle hold-down, latch iowaroots Commercial Listings 0 09-10-2004 08:33 AM
black rubber sealant looks like bacon dikku@mac.com Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-24-2004 06:26 PM
Black Tank Gunnyusmc Waste Systems, Tanks & Totes 3 07-02-2003 07:38 AM
