Old 05-01-2013, 08:42 AM   #43
2004 25' Safari
Laramie , Wyoming
Here is a waste hose that I ran across on the WWW. It is called the Polychute. I am considering it but the price is up there.
Here is a link.
Polychute
Does anybody have any experience with it?
mgap is offline   Reply With Quote
Old 05-01-2013, 11:16 AM   #44
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Don't recall the brand....
.....but it was replaced a few years ago after running over a piece of tire tread and losing the tube.
Replaced the PVC carrier with a longer one and carry two 15' sections.
It's brown......and stiff, must be the good stuff.
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-01-2013, 12:43 PM   #45
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Was it brown before you used it?
Gene
Gene
Old 05-06-2013, 01:52 PM   #46
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I measured the inside length of the tube under the AS and its between 45" and 46". I cut off some of my Rhino tube and reattached the connector and it's about 45 3/4" long. I snipped off the plastic ears on the main connector. The other end has the 90 deg translucent fitting and it fit into the tube. The trailer is in storage and hope to take it back in a couple of days to try. Fully extended its about 13 feet long now compared to 15 feet in its original length. It would be convenient to to have two of these tubes to put a 2nd hose and some other fittings. I had this amongst my water hoses in the rear bump tray of my Classic.
Kelvin
Old 05-06-2013, 02:06 PM   #47
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Kelvin
Just like this? We just got back from a club campout in OKC and you can probably tell we came through some rain. When I added the 2nd tube, I drilled a hole in the side of each cap to install an elastic cord that tensions the two covers towards their closed position so they won't wiggle open.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-10-2013, 03:41 AM   #48
KJRitchie's Avatar
2008 25' Classic
My modified Rhino hose now fits in the Airstream storage tube. Clipping off ears off the trailer connector fitting and shorting the tube worked. Granted I have only 13 feet now but I haven't needed this length as of yet.
Where did you get the 2nd tube and was it easy to install?
Kelvin
Old 05-10-2013, 07:18 AM   #49
2008 27' Classic FB
Burkburnett , Texas
Kelvin
A local RV parts store looked up the Valterra PN and ordered one for me. If you Google for EZ Hose Carrier Black you will find a number of lengths and sources. It looks like even Camping World now carries a longer one in black.
The factory mounted the original using lag screws through the belly skin into a small piece of aluminum backing plate. I wasn't prepared to get behind the skin so I obtained 4' of aluminum bar stock from a local home improvement store. As I recall it was about 1" by 1/4". I cut it into two 2' lengths, pre drilled them and then used lag screws for the tube mounts and 5 anchor bolts spaced along each bar to secure it to the belly skin. I don't recall exactly the type of anchor bolts, but I remember looking at many styles to find ones that would expand flat against the back side of sheet metal. It probably wasn't necessary but for belt and suspenders I used adhesive between the bars and the belly skin. I also added a touch of adhesive to the inboard end caps to discourage them from coming loose.
AIR 47751
Old 05-10-2013, 08:49 AM   #50
KJRitchie's Avatar
2008 25' Classic
Thanks, that seems to be a lot of work and if I need an extension I'll store it in the tow vehicle.
Kelvin
Old 05-10-2013, 09:04 AM   #51
Bend , Oregon
I own a 2013 Sport 22 and the sewer tube is about 46". I purchased the Camco 20' Revolution sewer hose that breaks up into 2 segments from Walmart. I used a dremel to burr down the 'ears' on the fittings and was able to to fit the entire 20' segment into the 46" tube without any problem. I originally bought the Rhinoflex but for some reason it wouldn't collapse down very well.
chaeha is offline   Reply With Quote
Old 05-11-2013, 02:44 PM   #52
Master of Universe
Gene's Avatar
Aren't the "ears" referred to the parts that hold the hose to things? If so, how do you make sure the hose stays on the drains or together with extension hoses? I'd think you'd want to avoid a sewer hose coming apart.
Gene
Gene
Old 05-11-2013, 02:58 PM   #53
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I split a PVC pipe lengthwise. It springs closed enough to hold on to another section and creates a gutter into which I place the inexpensive hoses. I use leveling blocks to set slope.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-11-2013, 11:24 PM   #54
KJRitchie's Avatar
2008 25' Classic
Gene
The "ears" are the 5 or 6 extrusions around the outside of the trailer connector.
I just clipped mine down with a pair of wire cutters. I didn't cut them down flush. I think they are there as grip aids for installing and removing the hose. They don't get involved with the latching of the hose to the trailer fitting.
Kelvin
Old 05-12-2013, 02:52 PM   #55
Master of Universe
Gene's Avatar
Kelvin,
I think that is so. Mine is still packed away so I didn't get to look at it before I leaped forward and posted.
Gene
Gene
Old 05-12-2013, 03:38 PM   #56
2008 27' Classic FB
Burkburnett , Texas
Yes, the "ears" sole function is to provide some grip to tighten the locking collar on the hose and to attach the connector to the bayonet end on the dump valve assy. The whole assy will slide into the standard 4" square bumper tube common on white box trailers. I shaved my ears down with a belt sander so that it would slide into the round storage tube Airstream uses. I've not found that shortening the ears made any difference making a secure connection.
AIR 47751
Shower is spewing water from where the hose attaches... palmtreegirl Sinks, Showers & Toilets 26 03-29-2015 05:00 PM
Need help immediately on brake hose part mumbers dadstoy Classic Motorhomes 3 03-23-2012 05:09 PM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Sewer vent Vicki A. General Repair Forum 11 03-19-2012 11:22 AM
Newbie dumb question re sewer hookups Rich of SCal Waste Systems, Tanks & Totes 62 02-23-2012 07:12 AM
