Old 04-24-2013, 08:48 AM   #29
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Blueline
Check this out
Blueline RV Sanitation ? RV Sewer Hoses, RV Sewer Fittings, Supports and Hose Connections
The Blueline sewer hose and push on connections are good quality and store in the tubes attached under the RV. A lot of optional connections and accessories available.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 04-24-2013, 10:27 AM   #30
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by KJRitchie View Post
I've moved from a Casita 17' where I stored my Rhinoflex in the 4" square bumper. Now I have a 2008 Classic 25 and was disappointed in finding the Rhinoflex wouldn't fit in the sewer storage tube. I'll try trimming the fittings as suggesed. Right now its in my rear bumper storage tray. I've had the Rhinoflex for several years now and haven't had any issues with it.
I have to put mine in the rear bumper tray, which works out OK because I keep all the other sewer supplies in there as noted upthread.
With all the hoses and adapters I use up the whole drawer, and it works out pretty well because the bumper drawer doesn't lock and, also, is prone to gathering road dust, so it isn't good for much else.
The only problem is that there are some sites where it isn't possible to open the bumper drawer while parked because of sloping ground.
I'm going to check out the Sewer Solution.
I have had one for several years and only use it for dumping tanks at home, where I have city water and sewer but need to run the dump hose slightly uphill to reach a sewer connection. They're a hassle for routine use.
With the AS valves on my Classic pointing straight out and do not extend beyond the body can you attach the SS so the discharge is at the bottom and the hose input is on side or parallel to the coach body?
No. I use a straight extension connector, which works. A 45 degree extension connector would also work, perhaps better.
Old 04-24-2013, 10:34 AM   #31
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
What you need for sewer varies, but we have 3 pieces of hose of differing lengths, adapters for the campground drain, gloves, hose for backflushing and Flush King. We store all of this in a big plastic container and don't use the PVC storage under the trailer—the cap is hard to get on and off at times and the hose doesn't fit anyway. It is easier to have it all in one place. Another container carries the fresh water hoses, filter, pressure reducing fitting and attachment for filling fresh water tank.
These plastic containers take a lot of abuse and have to be replaced after several years. A 3rd one—formerly bought with cat food in it—holds the device that holds the hose off the ground. Never can think of the name of that device, but it fits perfectly in the cat food container. That lasts a year or two. It is also good for sitting on while doing sewer hookups and hitching and unhitching. I've never seen these cat food containers anywhere but Sam's Club—they're about 15" high and are good for many things a medium small bucket can do, but also have a cover. It is not cost effective to get a cat and join Sam's Club (we use someone else to get in) just to get these containers.
All these start cracking after a while. Duct tape will extend their life for months.
Gene
Gene
Old 04-24-2013, 10:45 AM   #32
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I believe that you can. Here is a photo of Lucy's SS set-up. I use a 6" straight clear sewer connection to make it more reachable. It also gives me an area to see what's going on during dumping. We have found that the Sewer Solution works much better that a "slinky".
Brian
SuEllyn & Brian McCabe
Old 04-24-2013, 02:11 PM   #33
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
The Sewer Solution may be our answer to dumping at home. We are looking into expanding our driveway so we can move out of the storage yard. We have a sewer clean out fitting in the back yard ~30-45 yards away from the driveway and very slightly up hill. Is there a maximum distance from the dump valve to the clean out fitting in the yard where the SS will no longer work that I should be aware of?
Thanks for your comments,
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 04-24-2013, 04:12 PM   #34
moosetags's Avatar
I'm not sure of the maximum run that the Sewer Solution is capable of, but I can tell you what works for us. At SuEllyn's Dad's house in Jacksonville we use the Sewer Solution with a combination of 40' of Sewer Solution hose and 40' of PVC. We are making an 80' run to the city sewer clean-out. There is about a 2' upgrade on the drain route. We have been using this set-up for over five years and it works great. As we use this dump often, we leave the PVC and one section of the SS hose (it makes a 90 degree turn) in place all the time. We have a similar set-up at home, but it is only a 50' run.
Brian
Old 04-24-2013, 04:53 PM   #35
Scott J-24's Avatar
Sounds like it should work for us. Thanks for the feedback.
WBCCI #1215
Air #54601
Old 04-24-2013, 07:33 PM   #36
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Kelvin
I use a 90° clear adapter between the outlet fitting and the SS head. I think that accomplishes what you are asking about.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 04-24-2013, 07:57 PM   #37
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
We, too, use the 90 degree clear adapter. Perfect solution-"Sewer Solution". Would never go any other way for this task. An extra hose has surely come in handy as well.
Silverbee is offline   Reply With Quote
Old 04-24-2013, 11:11 PM   #38
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Brian
Neil (FreshAir) uses his SS at home, says he pumps 40' up hill when needed. I have not dumped at home ye, would probably end up with 40' if needed.
Some folks thought the SS a hassle to use, but when I had to flush a corrugated hose before storage and it still was not clean, and compared it to the SS, I end up much cleaner, don't have to "save up" grey water to flush, and it is all pretty easy. I had to add a short clear extension to my attach point so I could access the hose fitting, and it turns out the clear portion helps me make sure my tank is clean. I use the tank flush fitting and the SS backflow until its looks clean enough, then add a couple gallons & tank stuff for the drive home.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 04-25-2013, 10:05 AM   #39
Master of Universe
Gene's Avatar
OK, I know some people are going to gross out, but why is it so important to get the sewer hose so clean? The tank can build up dried solids and block the outlet and drain seal, so it should be flushed pretty well, but the hose?
It is corrugated and never will get completely clean, but since it bends, stuff will break off and flush out the next time it is used. The SS hose will never be antiseptic either unless you chlorinate it.
I think it is safe to say no one uses sewer hoses for anything else, and hopefully uses gloves when handling this stuff, so why worry about it?
If you really want to worry, wear a moon suit too. It is inevitable that some stuff will get on your clothes as you handle these items—your gloved hand brushes against your pants, the hose hits your shoe or pants, you scratch your nose with your gloved hand without thinking—all sorts of opportunities. Not to mention all the spills around the dump drains that leave strangers' bacteria to be picked up by your shoes and items you put on the ground (then return to truck, later you move those containers, and sit on the tailgate or put your bare hand on it).
It sure is hard to live the antiseptic life. But you can do things reasonably (which, I admit is different for everyone) without worrying about every possible contamination. I think you have more to worry about from water borne diseases brought to your city water inlet at some campgrounds than you have from the sewer system.
Gene
Gene
Old 04-25-2013, 04:06 PM   #40
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I was 10 years old when we moved into the first house with indoor plumbing. The out house was a long way from the home for obvious reasons. There was no wash basin at the out house.
So dealing with the sewer hose is not that big of a deal to me.
At least we don't have to dig a new pit and move the out house when the old pit got full.
Old 04-25-2013, 07:39 PM   #41
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I'm thinking about this hose. It's a lot of money but if it lasts like they claim it might be worth it.
http://drainmaster.com/site/products/full-view/217
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-26-2013, 11:56 AM   #42
Master of Universe
Gene's Avatar
Products | Drain Master
This costs $159. Camco's Revolution costs about $30—we have used it for 3-4 years without a problem. If it falls apart soon, we can buy 4 more and still come out $10 ahead. Those 4 more would be good for another 12-15 years (at minimum) and by that time I'll be so old I'll be wearing Depends and won't need a sewer hose.
The Drainmaster looks like a good product and if you are going to be using a hose for 15-20 years or more, it might be cost effective. Seems like overkill to me. I expect once it has been around a while the price will drop because not too many people will spend that much for this type of sewer hose.
Camco has 2 sewer systems—Revolution and Rhinoflex. They cost about the same and look similar. A quick look at specs shows one hose (16') with Rhino and it is maybe stiffer. Revolution has two 10' hoses and is kind if floppy when propped up. I'd like stiffer, but prefer the shorter hoses for different applications. A long hose when the sewer is 5 or 6' away is a pain. One has orange ends and the other yellow.
Gene
Gene
Shower is spewing water from where the hose attaches... palmtreegirl Sinks, Showers & Toilets 26 03-29-2015 05:00 PM
Need help immediately on brake hose part mumbers dadstoy Classic Motorhomes 3 03-23-2012 05:09 PM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Sewer vent Vicki A. General Repair Forum 11 03-19-2012 11:22 AM
Newbie dumb question re sewer hookups Rich of SCal Waste Systems, Tanks & Totes 62 02-23-2012 07:12 AM
