Old 09-02-2016, 04:08 PM   #1
TinGrin
2000 25' Safari
Tucson , Arizona
Replacing knife valves in 2000 Safari 25
My dump valves are leaking and I went under the rig to see how to replace...no apparent access point. Am a retired RV Tech, and changed many valves before, but I could get to them. Is there some access point that I am missing?
This is my first Airsteam and we love it!
Bill
Tingrin is offline   Reply With Quote
Old 09-02-2016, 08:57 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Greetings from Colorado. I had to replace my dump valves on my 86 as well as install a whole new drain manifold on my 66. Here is what I learned.
The 86 has an ABS plastic cover. Then there is the insulated pan that covers the tanks so they can be protected and heated. The pan supports the tanks (black and gray water). So I removed the cover and the pan to gain access to the valves. Mine had Thetford, but I replaced them with new Valterra. Airstream uses a lot of rivets.
Some folks cut an access hole in the pan to save some time removing it. This also saves time if the valves need maintenance again.
I don't know how the year 2000 trailers are made, but it may be similar. The bottom line is dump valve maintenance on an Airstream is more work than some other brands.
David
Name:	1205 ABS Cover Removed.jpg
ID:	270630   Click image for larger version
Name:	1205 New Foam Insulation.jpg
Name:	1205 New PVC Drain Manifold.jpg
Jack Knife Gaucho, Maple color cabinets, Range Hood from 2005 Safari 19' Mtrid3r Airstream Classifieds 0 04-25-2015 03:29 AM
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 07:07 AM
French Army Knife Tin Hut Off Topic Forum 4 05-16-2004 02:11 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 05:01 AM
