Old 06-11-2009, 10:57 PM   #1
Aluminumluvr
AluminumLuvr's Avatar
1980 20' Caravelle
2002 25' Safari
San Diego , California
Question Replacing dump valves
Hello fellow streamers!
Looking for opinions regarding the replacement of the dump valves on my little Caravelle. Took it in to have them replaced and was surprised to see that the repair facility cut a hole in the belly and caulked it back together. Is this a common way to replace the valves or should I complain? Thanks in advance for your sage advice.
Lyn
San Diego
1980 Caravelle 20'
2002 Safari 25SS
2006 Toyota Tundra
AluminumLuvr is offline   Reply With Quote
Old 06-11-2009, 11:56 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my trailer had a bad creak in the floor and the repair dealer told me, up front, that to fix this they would cut a hole in the belly pan and cover it back up. I agreed to let them do it this way. No damage done, no future problems, and you can't see it unless you are laying on your back under my trailer. Will complaining now make things any better, I don't think so. But I do think they should have told you before doing the job. [option: cut hole in belly pan to gain access, or remove intire belly pan for four times the labor cost]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-12-2009, 10:32 PM   #3
Aluminumluvr
1980 20' Caravelle
2002 25' Safari
Thanks, Bob. Maybe the real issue is the lack of communication on the shop's part. That has definitely been a problem and the reason a few things had to be redone. Glad to hear there were no further problems with the cut in the bellypan.
Thanks again!
Lyn
San Diego
1980 Caravelle 20'
2002 Safari 25SS
2006 Toyota Tundra
Dump valves don't work! dawncquinn Waste Systems, Tanks & Totes 4 07-11-2008 01:41 PM
Argosy Dump Valves or something else?? Denise M. All Argosy Trailers 6 05-21-2007 04:36 PM
Dump Valves - Need Help lebolewis Waste Systems, Tanks & Totes 7 09-06-2006 06:52 AM
toilet and dump valves raebaker06 Waste Systems, Tanks & Totes 8 09-04-2006 05:06 PM
Knocked off dump valves! Astrodokk Airstream Motorhome Forums 7 07-13-2003 09:32 PM
